Great work Garth, Barrells look excellent. Mark Regards Markwarren (Mark) Admin
Hi Garth. Very nice work with the air brush. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Alan, Tony, Mark and Ian. Thank you for looking in and for the kind words. Regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi All, I Started preparing the hull for lighting. The LED’s for the lanterns will each require a resistor. It will be possible to make a small pc board and hide it behind the aft bulkhead, but I did not relish the idea of running (and keeping track of the polarity of all those tiny wires). To simplify this, I stripped down some household wire and made two ‘Buzz Bars’ to connect the lanterns and resistors. It is about Ø1mm. I then cut slots into the top of the bulkheads to accommodate the wires. Once the wires were Superglued into the slots, I replaced a small piece of insulation on the ends – this indicates the polarity. I then soldered on the resistor opposite each lantern. Next will be wiring the LED’s and making the lanterns. Kind regards, Garth Garth attached the following image(s): "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Nicely done Garth, will be interesting to see how it all turns out.... Regards Alan
Nice work Garth, look forward to seeing them working. Mark Regards Markwarren (Mark) Admin
Garth Nice idea to have some lights in there. Hope it all goes to plan for you. Happy Modelling
 Rank: Pro  Groups: Registered
Joined: 26/01/2014 Posts: 119 Points: 343 Location: Newcastle
I like the idea of a bus bar, will be interesting to see how it turns out Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
Hi Guys, Thanks for looking in. The lanterns are coming on, but the armature wire is not working as hoped. I will post some pics when I have installed them all. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi Garth, hope you get it sorted! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Phil, Thank you for looking in. Lanterns are done, not 100% happy, but it will do. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi All, Finally the lower deck lanterns are fitted. Below is my description, please bear in mind that this is a work in progress and I think that my method requires some fine tuning. I decided to light the lanterns using surface mounted LED’s. They fit comfortably inside the lanterns body. Unfortunately, I have used up all my thin wire that I used on the Victory’s lanterns and have had to use Armature wire instead. The coating on the wire is extremely tough and has to be removed in order for the solder to stick. To do this, apply an open flame to the tip of the wire and the insulation burns away. Trim the end and apply the solder. I stuck the LED’s to a piece of scrap styrene with double sided tape to hold them and tinned the ends. Hold the tinned end of the wire to the led and touch the soldering iron tip to the joint. Note: I cut one wire slightly shorter and soldered this to the Negative side of the LED. This just helps with the keeping track of the polarity during the installation. I assembled the lantern bodies according to the instructions with the following exceptions: I used solder rather than superglue, I drilled a Ø1mm hole in the corner of the top for the wires and I decided not to fit the bottom plate, just to help spread the light. Once the all the assemblies were complete, applied a small blob of silicone sealer and ‘glued’ the LED’s in place. This needs about 6 hours to dry. Next I fitted the lanterns and soldered the wires to the ‘Buzz Bars’. Once all was installed I painted the wires matt black. In hindsight: The Armature wire is really hard to work with – I must find a suitable alternative. If you follow my method – test the assemblies after every step, especially before the final solder. Its soul wrenching to have to remove a fitted lantern and trouble-shoot the connections. I have noticed that some of the lanterns flicker when the model is bumped, but after spending about 14 hours on them, I really don’t feel like going back. Perhaps there will be some dead lanterns once the hull is complete; I’m just going to have to live with that!!! Kind regards, Garth Garth attached the following image(s): "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Credit to your patience with this one Garth. Had not realised you were putting the leds into the lanterns and they are so small. I think you have done a great job on these and they will look fantastic once that section of your build is complete. Happy Modelling
Really inspiring piece of work Garth, those lanterns look fab.....  Regards Alan
Patients of a saint. Those lanterns look terrific. Mark Regards Markwarren (Mark) Admin
Fantastic work Garth, those lanterns are a masterpiece. Your soldering skills are really showing their worth now. Just a quick question. Did you use coloured LED's, or did you lower the luminosity of them with the resistors? Well done that man Happy building David
Hi Tony, Alan Mark & David, Thank you for looking in and for the kind remarks. David. Sorry, I should have mentioned in the beginning, the Surface Mounted LED's are yellow with a 840Ω resistor and a 12v DC Power supply. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi Garth. Great job on the lighting. looks fantastic. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
The lanterns look superb, great job.
Excellent work on the lanterns. Can only make for a superior finish to your model. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guest (6)
