Hi coming along at a fair rate.do like these skeleton kits.must try one sometime.doing a great job.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Thanks for looking in and your comments Mick Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All More progress, the rear cockpit divider plate, floor, cockpit seat,seatbelts,joystick,various instruments,rudder pedals and leather bag have all been fitted to the fuselage. The wood floor and seat were painted using the AL Wood Grain Painting Mask I would recommend practicing with the mask 1st if you want a good finish. Next you add the rudder and elevator control cables then the bracing wires and turnbuckles to the rear of the fuselage are added, I nearly have all of them in position now. When fitting the bracing wires no need to make them bar tight as after the glue has set you can use a heat gun the shrink them tight as the wire is made of a heat shrink material. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That`s looking fine Andy. Superb detail. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking great Andy  AL have really put some thought into this kit, great idea to use heat shrink material. Al
 Thanks for looking in and your comments lads Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks like a great kit you have there Andy!  Top work so far! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Thanks for looking in Phil and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Small update, the bracing wires are all done and the tailplane added to the fuselage. If your going to build this the mounting pegs on the fuselage will need to adjusted/reduced in diameter so the tail/elevator section sits correctly on the fuselage. After the tailplane was fitted the two braces were added then the control wires from the joystick were connected. Lastly the rudder was fixed in position with two brackets and brass pins then the control cables were added. Note. I used a heat gun designed to shrink R/C model aircraft covering to shrink the heat shrink wires. Just be careful when doing an overall shrink on the fuselage. Link below to the heat gun I used:- https://www.towerhobbies...?&I=LXHZ16&P=ML
Looking good Andy, really nice progress.... Regards Alan
Really coming along now Andy  looks superb  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Looking great Andy, really nice work with all those bracing wires.
Really nice work Andy, you’ve certainly cracked on with this. Those bracing wires look fiddly. Great work Mark Regards Markwarren (Mark) Admin
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Those bracing wires look fun. Really looking the part now though. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Thanks for looking in Derek and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The ammo boxes were made up and painted along with the oil tanks and fuel tank. The large oil tanks are due to the engines lubrication system which was a throw away system. The castor oil was mixed with the fuel through the carburreta then it passed through the cylinders and was ejected out of the exhaust ports and hence the oily faces of the pilots from the spray back who flew these machines. The next thing to be added is the aileron cables once done the engine firewall was made up with the carburreta and mount added to the rear. The fire wall is added to the fuselage using 4 long bolts and nuts. Then the carburreta T piece that exits on either side of the fuselage went on. The last part added was the fuel tank. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
This is looking great and really gives you an insight of how they were put together, nicely done Andy Al
Really great build, this is definitely a show piece model. Mark Regards Markwarren (Mark) Admin
Hi Andy, coming along at fair pace ,looking great.cheers Mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
