here is issue 12. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
attaching the starter motor,distributor,and the carburettor assembly attached to the engine block. stevegbr attached the following image(s):
here is issue 13. stevegbr attached the following image(s):
fitted the filter head and hose. stevegbr attached the following image(s):
fitted the battery box in to the engine block. stevegbr attached the following image(s):
here is issue 14. stevegbr attached the following image(s):
assembled the ignition lead and coil. secured to the engine block, and engine breather fitted. stevegbr attached the following image(s):
fan belt and pulleys fitted to timing case cover. stevegbr attached the following image(s):
dynamo is fitted with end cap. stevegbr attached the following image(s):
large pulley fitted to fan belt. stevegbr attached the following image(s):
here is issue 15. stevegbr attached the following image(s):
exhaust manifolds fitted to engine block. stevegbr attached the following image(s):
fitted the rev counter generator in the end of cam cover. stevegbr attached the following image(s):
cylinder head fitted to left hand engine block. stevegbr attached the following image(s):
timing cover and right hand side block secure the engine together. stevegbr attached the following image(s):
coil lead is pushed in to distributor. stevegbr attached the following image(s):
