Joined: 25/03/2011 Posts: 22 Points: 56 Location: Sheffield uk
Hi all, received issues 3 & 4 this week so had a god at putting carbon on to the top suspension arm & push-rod. What do you think ? I did the top susp, in two sections..  what a jod 3 hrs and 1 full sheet later done better order some more i'm going to need it The carbon i have use is Scale Motorsport 1/12 scale plain weave and i will be using a different one studio 27 for the wings
Joined: 01/05/2011 Posts: 52 Points: 152 Location: England
are these sheets water slide? Builds in Progress
D'Ag 1/8 Mclaren MP4/23 Tamiya 1/24 Toyota Corolla WRC
Done a great job there glen but a whole sheet!!!! ok i'm guessing some mistakes on the way?? lol one good tip is to give them a coat of halfords clear Lacquer or if you want to try it Tamiya clear smoke. Yes these are waterslide Decals Timson72
Warthog wrote:Done a great job there glen but a whole sheet!!!! ok i'm guessing some mistakes on the way?? lol one good tip is to give them a coat of halfords clear Lacquer or if you want to try it Tamiya clear smoke.
Yes these are waterslide Decals Timson72 Hi, Thanks Spencer, first time trying this, well not quite a full sheet and yep i made some mistakes  . Tried to do it all in one go but a to complicated shape, then did it a again and still weren't happy so ended up doing it in two sections, i'm going to clear lacquer all my carbon parts. clear smoke sounds interesting
tried to buy some last night,they out of stock Builds in Progress
Timson72 wrote:tried to buy some last night,they out of stock Where are you trying to get them from? Try Hiroboy.com
Clear smoke is the best way to go, as I think the carbon effect seems a bit harsh, and may need toning down. Well done though tricky pieces to put the transfers on.
that's where i tried mate,ive asked to be emailed when back in stock. Builds in Progress
Austin wrote:Clear smoke is the best way to go, as I think the carbon effect seems a bit harsh, and may need toning down. Well done though tricky pieces to put the transfers on. Hi, do you have any imfo on the tamiya clear smoke as i'm looking but cant find it, Thanks for the comments
Hi, I can't remember which one it is, TS-71, or X19. The reason I said use clear smoke is when you see carbon fiber it looks black till you get close, when there's to much detail, as there is with many of the carbon fiber decals, it just looks false. As the model is gonna cost about £650 and your gonna mod it, it's worth doing it well. Keep it up bud your doing a good job.
Hi all, just sprayed over the carbon with Clear Smoke Tamiya PS-31 then applyed a top coat of Semi Gloss Clear Tamiya TS-79. here a few pics. Also put carbon on the front wing plates and going to put a coat of gloss clear
Good stuff Glen MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks, now i know what the finished thing looks like i can get on and do the other side and all the other parts i'm going to do ...... its going to be a longggggggggggggggg job
 Rank: Pro  Groups: Registered
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
Hi. Cracking job there mate!! I'm. Middle of doing this myself! Need to smoke the decals but I was struggling to find clear smoke in spray form. Where did you get the paints from? I was looking for clear smoke x-19. Might have to steal your idea and use those paints. I did consider brushing on the x-19 clear smoke. Thought any minor brush strokes would add to carbon effect?? Probably a bad idea! Lol. If at first you don't succeed........skydiving is not for you!
scottww86 wrote:Hi. Cracking job there mate!! I'm. Middle of doing this myself! Need to smoke the decals but I was struggling to find clear smoke in spray form. Where did you get the paints from? I was looking for clear smoke x-19. Might have to steal your idea and use those paints. I did consider brushing on the x-19 clear smoke. Thought any minor brush strokes would add to carbon effect?? Probably a bad idea! Lol. Hi, thanks, got my paints off ebay from rcpitstop smoke £5 semi clear £6.50... just typ in tamiya paints
