13 Pages «<678910>»
Stevegbr E-type Jaguar Build. Options
stevegbr
#141 Posted : 04 November 2017 01:15:35
secured the bracket, and left hand lower brace.
stevegbr attached the following image(s):
stevegbr
#142 Posted : 04 November 2017 01:17:12
here is issue 27
stevegbr
#143 Posted : 04 November 2017 01:18:34
here are the parts
stevegbr
#144 Posted : 04 November 2017 01:22:20
the caliper is attached to the disc and arm, then secured to the upper and lower wishbones.
stevegbr
#145 Posted : 04 November 2017 01:26:23
the shock absorber is assembled and secured with a pin and screw.
stevegbr
#146 Posted : 04 November 2017 01:28:53
here is issue 28
stevegbr
#147 Posted : 04 November 2017 01:29:48
here are the parts.
stevegbr
#148 Posted : 04 November 2017 01:31:52
#149 Posted : 04 November 2017 11:41:47
Making really nice progress Steve, well done....Cool Cool
#150 Posted : 04 November 2017 13:57:53
Glad to see you back on this steve BigGrin looks greatDrool regards PhilCool
stevegbr
#151 Posted : 04 November 2017 18:13:49
thanks alan and phil, nearly catched up now. BigGrin BigGrin
stevegbr
#152 Posted : 04 November 2017 21:20:52
here is issue 29
stevegbr
#153 Posted : 04 November 2017 21:22:31
here are the parts.
stevegbr
#154 Posted : 04 November 2017 21:25:16
putting the torsion bar on the sump cover.
stevegbr
#155 Posted : 04 November 2017 21:26:47
here is issue 30
stevegbr
#156 Posted : 04 November 2017 21:28:20
here are the parts.
stevegbr
#157 Posted : 04 November 2017 21:32:32
the fan assembly, fitted fan to shaft, and fan motor to header tank.
stevegbr
#158 Posted : 04 November 2017 21:39:56
here is issue 31.
stevegbr
#159 Posted : 04 November 2017 21:46:05
here are the parts
stevegbr
#160 Posted : 04 November 2017 21:49:00
header tank fitted to chassis, and front sub frame, left and right mounting flange fitted to chassis
13 Pages «<678910>»
This page was generated in 0.386 seconds.
