Dave Very neat planking work and you are getting through that part at a pace. Hope it all continues well for you. Happy Modelling
Great job on the planking, good to see her taking shape.
Nice work Dave  she's looking good. Al
Progressing really well Dave  great stuff  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
SAhe's taking shape more now, excellent work. Regards Markwarren (Mark) Admin
 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 10/09/2017 Posts: 65 Points: 218 Location: Leicester
Thanks for all your comments it really appreciated hope to spend the day in the man cave tomorrow finishing off the port side and starting the starboard. Off work this work
 Looking good, you will soon be fitting the armour belts Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I'M STUCK , can some one show me a clear picture of the sturn from frame 12 to 14 please see picture as not sure how to do this bit as picture,s in PDF isn't very clear when you try to enlarge. Dave 71 attached the following image(s):
 Hi Dave If you look at my build diary page 3, post #50 onward you can see how I did mine:- http://forum.model-space...osts&t=2756&p=3
Did the kit come with some triangular balsa as this is used to act as a filler between the planks and the armour strip. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, didn't won't to do it wrong,it's good to no there's a lot of surport when you need it and to answer your question I've not found any triangular pieces yet will double check.
Had to undo some of the hard work I'd spent doing over the weekend as I'd used the wrong stakes. That will teach me to read the instructions properly Andy point out there should be some triangular stakes witch I found after I'd just about finished one side of the boat. Any way after undoing it all I've manage to put in right now, see picture's. Dave 71 attached the following image(s):
And very nicely done Dave. Its not easy having to take apart something you have already put together but if you had not mentioned it you would never have guessed. Credit to you on the planking because you have managed a very nice looking hull in a very fast time. Happy Modelling
Thank,s Tony ,be leave you me it wasn't easy to put it right but I daresay I won't be the first or the last to make a mistake and there'll probably be more mistake to come but if there,s one thing I have learnt it,s to ( read the instructions properly.)
 Plankings looking good and glad you got the hick-up sorted out she's back on track now, nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice planking, look forward to more updates. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Glad you sorted it Dave  looks great  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Looks great Dave  pleased you got it sorted. Al
Great job on the planking, looking good.
All the planking is now done on the side of the Hull. So now concentrating on some of the metal work starting with the base.will post some picture,s when there's some thing done .
 Hi Dave Glad your progressing well, Just a word of warning on the metal parts the sides are not square on the base so assemble on a flat surface with epoxy and then use car filler on the top surface to get a good flat base for the rest of the superstructure to sit on. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
