Top Deck Options
riff-raff
#1 Posted : 08 May 2011 21:14:09
I am just starting on the top deck and have come to the point where I am filling the sides of the deck up to the hull sides.
I have removed the frames from the area above the rigged guns on the lower deck but should I sand the hull in this area so that it sits level with the finished deck?
At the moment it sits about 1mm higher than the deck
Thanks
Built:
#2 Posted : 09 May 2011 09:01:23
Can you post a photo?
This page was generated in 0.028 seconds.
