51 Pages «<2425262728>»
DaDokta`s Build Options
DaDokta
#501 Posted : 08 November 2017 11:34:33
Thanks again for the encouraging comments, guys!
I added the pin rails at the foremast - the problem was that with building the gratings more narrow than in the instructions - the pinrails were shorter and so i had not very much space for the Pins.
I hope this won`t haunt me once the rigging comes up.
Also i attached the two cannons to the deck - didn`t want them just standing there - so i added some securing ropes - don`t know if that`s correct - but it would make sense.
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
DaDokta
#502 Posted : 09 November 2017 08:55:07
It occurred to me that sometimes some of the pics are shown in a different orientation, also sometimes i have to reload pages several times to be able to see all pics.
Do you have these problems as well?
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#503 Posted : 09 November 2017 09:23:30
Hi Walter, having to refresh the page to view images is a known problem and is with the IT team. The pics showing in a different orientation is not something I have experienced or seen before nor has this been previously reported. Will take a look and see what I can find.....Cool Cool
DaDokta
#504 Posted : 10 November 2017 12:16:08
Maybe the wrong orientation was my fault.
But thanks Alan!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#505 Posted : 13 November 2017 11:04:53
Next up was the gratings and pin rail around the main mast.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#506 Posted : 13 November 2017 12:54:57
Beautiful work as always Walter.
DaDokta
#507 Posted : 14 November 2017 09:52:00
Thanks Graeme!
The last four of the cannons were attached.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#508 Posted : 14 November 2017 10:25:43
Moves on another stage and looking very good indeed.
NikonD60
#509 Posted : 16 November 2017 01:15:41
Looking great Walter. Keep the pictures coming. Excellent work.
Alan.
Today is the tomorrow you wished for yesterday!
#510 Posted : 16 November 2017 08:32:29
Nice update Walter. Coming along very nicely.
Chris Cool
#511 Posted : 16 November 2017 10:32:32
Loving the work you have done there Walter...Like it very much!! ThumpUp
DaDokta
#512 Posted : 20 November 2017 09:47:45
As always - thanks for your nice comments!
I invested much thought in how to make the binnacle.
I used Mike`s enhancement parts - but wanted to enhance them further.
As you can see i first cut out the middle part so that only the frame remained.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#513 Posted : 20 November 2017 09:51:02
Then i produced the two compasses out of 3x3mm wood. I decreased the picture of a compass-rose in size, printed it and glued in on top.
The lantern i made out of a toothpick.
The three part were glued on a piece of wood and inserted into the frame.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#514 Posted : 20 November 2017 09:52:58
At last i added the PE-parts and the windows.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#515 Posted : 20 November 2017 10:00:29
Nice job Walter, looks brilliant!
#516 Posted : 20 November 2017 12:14:14
Walter
Very detailed little part which will add a lot to the overall build.
#517 Posted : 20 November 2017 16:54:50
Lovely detail work Walter BigGrin impressive.
#518 Posted : 20 November 2017 19:10:39
BigGrin Very nice work WalterCool
#519 Posted : 20 November 2017 21:55:30
Hi Walter.
Great work on the compasses. look forward to the next update.
Ian Cool BigGrin
NikonD60
#520 Posted : 21 November 2017 00:25:54
Nice work Walter. Looks fiddly but you've done a good job.
Alan.
Guest (14)
This page was generated in 4.364 seconds.
