 Rank: Pro Groups: Registered
Hi guy's and girls
I'm on the verge of calling it a day as I'm finding the planking extremely difficult and this is my last attempt at trying to understand the planking, so please any help would be appreciated.
I cannot prevent clinkering, no matter what I try, I have made sure the frames are sanded right and I chamfer the planks, but in some cases this makes the clinkering worse, I have even packed out the frames where the clinkering occurs but this is no help as it puts the next layer of planks out too and in some places the clinkering is as deep as the depth of the plank. This model is definitely not for the beginner, not in my case anyway, and I would have quit ages ago if it were not for the fact that I did'nt want to waste the money I had already spent but now I have spent more and I'm still in the same boat with even more money possibly wasted.m I have looked through other people's builds and tried to understand their advice, but to no avail as I'm more of a "learn better with practical tuition" guy so I dont hold out much hope of finishing this model. Thanks for any help offered in this matter. Wallace.
Hi Wallace,
Have you tried chamfering the inside edges of the planks so they sit better with the adjacent planks already fitted?
If not just remember that the planks are 2mm thick and you can get away with a fair bit of sanding. Have you thought about adding a veneer? In my view its a good thing to consider if its your first build.
best, Tom
Joined: 07/09/2010 Posts: 83 Points: 285 Location: portsmouth
i have got the same problem not quite as bad as you though by the sounds of it, i socked my planks in boiling hot water for about a hour then nail them into position ands leave them for a few days, this gives them time to complete dry into the shape needed,on the ones that i have got problems with there not to bad so hoping to fill and sand them downs smooth. are you painting or varnishing the hull,as painting you shouldnt be able to see any defects. hope this might help this is also my first build like you i have thought of giving up but have perserverd. maybee the more experenced modlers will have other solutions that could help us both?? Brian
Current Builds HMS Victory HMB Endeavour HMS Hood PLAY UP POMPEY!!!no wise cracks
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi Wallace,
I experienced quite a bit of clinkering on my planking & I had also tapered, chamfered, packed our ribs etc Nothing I did seemed to help.
I can't offer you any magic advice to help stop this, however I was surprised how good it looked after sanding.
All I can say is keep going & give it a jolly good sanding & I reckon you'll be pleased with the results and at the end of the day there is always the filler pot & paint!
Keep going it'll be fine!
Wilfy
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Wallace
Dont give up. I had a terable time with my planking and sufferd from clinkering. but a good sanding ended nup with a half decent result. After seeking advice from others on here and looking at there build diarys i decided to put a 2nd layer on and venear the hull. It now looks a lot beter than i ever thought it would.
Hope you still carry on the build and if you do good luck
Foz
Joined: 30/03/2010 Posts: 47 Points: 156 Location: Glorious Devon.
Like you I was on the verge of giving in half way through the planking. I followed all the advice but still got a lot of clinkering. However with some good quality filler and sanding I'm really happy(ish) with the final result. I'm now going down the painted route anyway so I'm confident the final result will look fine.
I am also a novice builder and TBH I had a reasonable amount of clinkering!
However I looked at the depth of the clinkering and as I still had enough overlap of wood took the option to sand smooth.
I have done it and am VERY happy with the result. Don't be dismayed about it, just give it a sand and then sitback and admire your work!
Hi there wallace, I have experienced the same thing on this build, don't give up mate, a bit if filler and a good sanding, be surprised at the end result...Hang in there... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
there is other ways of planking {the pros are cringing}lay four middle plankes extend the thired but do not glue this will guide the 4th plank start the 4th ford plank from the middle letting it bend natural around the bow takeing its own shape with out forceing it in place same with aft plank then work back wards filling in this way when checking the next plank lay it on the one that was last laid it will show how much to take off to fit it, you will find the taper different from the other way
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
Don't give up, it's amazing the results you will get from sanding and filling, my Cutty Sark build has been terrible because of the wood and components supplied, but some filler and some paint has worked wonders. I'm not painting Victory, but looking at the pics in the magazines, I should think even a novice could do a very good job, because of the way the wales go on, so think about painting (not copper plating, as if you are finding planking difficult, this may be a struggle)think how it will look and then decide whether to give up or not, but I think all your woes could be sorted by painting. Come on you Jimmies
Joined: 23/03/2010 Posts: 205 Points: 598 Location: West Midlands
Dont give up, when you have sanded down the planks you will have a superb model, attached is my build after a good sanding. Believe me there were times when I did not think I could complete the planking but perservere, it is worth the effort. Happy building CMB attached the following image(s):
Thanks for all the advice guy's. I will give it another go and see what occurs. Once again thanks for all your help.
Good luck wallace My planking wasn't brill but I filled with a view to painting then copper plating. all I can say is don't rush and I found a lot of swearing and a stress toy helped “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
