Silicone tube being cut on C57 Options
#1 Posted : 10 November 2017 20:01:25
Hi may be it just me, all was going well till put body on,it sheared me tube in half.i have got the bolt to one side as it shows on band. Anyhow I loosened band pushed it as far back as it will go, filed bout 1.5mm out back of rectangle hole here, but it sheared again. In the end I removed the whole of the back bit, then cut me band so nothing was in the hole anymore.refixed band with epoxy.and it now runs as smooth as owt. Luckily I got plenty of tubing from my nitro days,to replace the ones I had.as I say may be just me and I hope nobody else has this issue.cheers mick. :-D
This page was generated in 0.081 seconds.
