PACK 12 Stage 93 The ash box Here we screw together the parts that make up the ash box, then fit this to the chassis.2 of the screws are a real pig to get at, but got there in the end. Also we just test the running of the train. Just to make sure it not sticking anywhere. Mine needed no adjustment. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Coming on very nicely. Mark Regards Markwarren (Mark) Admin
PACK 12 Stage 94 The motor Here we first test the motor make sure it works, then fit it's mounting plate to the chassis, then fit the motor to this. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
PACK 12 Stage 95 The gearbox Here we screw together the various parts that make up the gearbox, and fit this to the axel of the drive wheel then connect it to motor via silicon tube, finally give it a test run on the Base to make sure all is well, it was on mine.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
PACK 12 Stage 96 The brake shoes First of all we put together the 6 brake shoes to there mounting brackets 3 left hand 3 right, then attach these to the chassis, and adjust them to fit the radius of the wheels, then join the pairs together with a beam across the bottom, cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Its coming on well Mick. Not long now until you can power it up and get those wheels running. Happy Modelling
Hi Tony had me test run chassis only cheers mick. https://youtu.be/SwOTR79BFiE
Glad it ran fine Mick  look forward to seeing the end result. Al
Looks fab Mick, a great looking build.... Regards Alan
PACK 12 Stage 97 The couplers Thanks to all who looked in and left comments much appreciated. Here we put together the front and rear couplers and fit them to the engine and tender. The front one was supposed to bolt on, but my bumper had clearance holes in it, not tapped so had to glue this assembly to the front, then glue in the bolts. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
PACK 12 Stage 98 The reverse bar Here we assemble the reverse bar, push one end through the cab wall, the other clips into the link sticking through the running board. Cheers mick mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
PACK 12 Stage 99 The pneumatic pipes and coal Here we glue in the copper pipes on the left hand side, and place the coal in the tender. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
PACK 12 Stage 100 The number plates and District tags And finally the end of this great kit, just glue in 4 lengths of wire to the number plate with holes in it, and glue this to the rear of the tender. Then glue the other number plates and District tags to both sides of the cab. Thanks to all who followed this build. Final pics and video will be put in finish gallery. Cheers mick mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 All done and nice finish Mick Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Well done Mick  great job. Al
She looks fab Mick, great piece of work.... Regards Alan
fantastic build mick. well done. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (10)
