9 Pages «<789
Micks aka Mogwai C57 build diary Options
#161 Posted : 11 November 2017 18:06:07
PACK 12
Stage 93
The ash box
Here we screw together the parts that make up the ash box, then fit this to the chassis.2 of the screws are a real pig to get at, but got there in the end. Also we just test the running of the train. Just to make sure it not sticking anywhere. Mine needed no adjustment. Cheers mick. BigGrin
#162 Posted : 11 November 2017 18:11:37
Coming on very nicely.
#163 Posted : 11 November 2017 18:11:52
PACK 12
Stage 94
The motor
Here we first test the motor make sure it works, then fit it's mounting plate to the chassis, then fit the motor to this. Cheers mick. BigGrin
#164 Posted : 11 November 2017 18:18:43
PACK 12
Stage 95
The gearbox
Here we screw together the various parts that make up the gearbox, and fit this to the axel of the drive wheel then connect it to motor via silicon tube, finally give it a test run on the Base to make sure all is well, it was on mine.cheers mick. BigGrin
#165 Posted : 11 November 2017 18:26:12
PACK 12
Stage 96
The brake shoes
First of all we put together the 6 brake shoes to there mounting brackets 3 left hand 3 right, then attach these to the chassis, and adjust them to fit the radius of the wheels, then join the pairs together with a beam across the bottom, cheers mick. BigGrin
#166 Posted : 11 November 2017 20:09:30
Its coming on well Mick.
Not long now until you can power it up and get those wheels running.
#167 Posted : 11 November 2017 20:39:33
Hi Tony had me test run chassis only cheers mick.
https://youtu.be/SwOTR79BFiE
#168 Posted : 11 November 2017 22:02:49
Glad it ran fine Mick BigGrin look forward to seeing the end result.
#169 Posted : 12 November 2017 00:33:55
Looks fab Mick, a great looking build....Drool Drool
#170 Posted : 12 November 2017 17:25:31
PACK 12
Stage 97
The couplers
Thanks to all who looked in and left comments much appreciated. Here we put together the front and rear couplers and fit them to the engine and tender. The front one was supposed to bolt on, but my bumper had clearance holes in it, not tapped so had to glue this assembly to the front, then glue in the bolts. Cheers mick. BigGrin
#171 Posted : 12 November 2017 17:31:02
PACK 12
Stage 98
The reverse bar
Here we assemble the reverse bar, push one end through the cab wall, the other clips into the link sticking through the running board. Cheers mick BigGrin
#172 Posted : 12 November 2017 17:35:45
PACK 12
Stage 99
The pneumatic pipes and coal
Here we glue in the copper pipes on the left hand side, and place the coal in the tender. Cheers mick. BigGrin
#173 Posted : 12 November 2017 17:44:22
PACK 12
Stage 100
The number plates and District tags
And finally the end of this great kit, just glue in 4 lengths of wire to the number plate with holes in it, and glue this to the rear of the tender. Then glue the other number plates and District tags to both sides of the cab. Thanks to all who followed this build. Final pics and video will be put in finish gallery. Cheers mick BigGrin
#174 Posted : 12 November 2017 19:07:52
BigGrin All done and nice finish Mick
#175 Posted : 12 November 2017 20:43:24
Well done MickCool great job.
#176 Posted : 13 November 2017 09:15:51
She looks fab Mick, great piece of work....Cool Cool
#177 Posted : 25 November 2017 22:01:26
fantastic build mick. well done.
Ian Cool BigGrin Drool
9 Pages «<789
This page was generated in 0.408 seconds.
