PeterB Options
PeterB
#1 Posted : 12 November 2017 17:08:07
Rank: Newbie
Subject: USS Constitution waterline model.
Posted: Sunday, Nov 12, 2017
G'mornin all.....
I'm a new forum member and very interested in the USS Constitution Kit, but would greatly prefer to end up with a "waterline" model when finished.
- Does the kit possibly include instructions for trimming keel, etc to make a waterline model?
- Has anyone tried this and possibly willing to share "how"?
Thanks very much for any guidance/assistance....
PeterB
#2 Posted : 12 November 2017 17:13:54
G'mornin all.....
PeterB
Peter
The instructions cater for a full hull ship.
If it helps you can read the instructions here
https://www.model-space....e-uss-constitution.html
Look under the build tab
Not sure it would be that easy to convert to waterline unless you have some experience of ship building,
#3 Posted : 12 November 2017 19:06:40
BigGrin Hi Peter
Welcome to the forum as for waterline models I think someone did it with the Victory a good while back. I think he built the hull then cut the bottom off it either way you would need careful planing to carry this out.
#4 Posted : 12 November 2017 20:05:27
Welcome to the forum. I have not seen any of the DeAgs' period ships built as a waterline model but I would imagine that you would have to build the hull then make a jig to hold it on it's side and use a band saw to cut the bottom off the hull. As Andy says, it would take careful planning to get an accurate cut and would be an expensive mistake if it went wrong.
#5 Posted : 12 November 2017 20:19:12
Peter
Just thinking about this question again and one option might be to build it as a full hull kit and then set the hull into a display base designed to look like the sea but with a suitable cut out to "sink" the ship upto its waterline mark.
At least that way if you were not happy with the result all you have lost is time in making the seascape.
Sure there are other options but i was thinking a thick polystyrene layer with the hull shape cut out so that the ship sits into that. You could then build up the sea effect with the usual materials.
Just a thought Confused
PS
Just looked through youtube and while this is for a plastic model it describes what i am trying to get at above - hope it may help
https://youtu.be/yTth_QK0w7w
PeterB
#6 Posted : 12 November 2017 23:38:17
Rank: Newbie
In re: waterline model of USS Constitution..........
Wow - thanks for your thoughts, gentlemen! Sounds like I maybe need to rethink this idea but I'd like to go over the building plans to see if I can spot any possibilities first. Do they publish the later phase building instructions anywhere?
I'm wondering about starting at the "finished" end to locate the waterline on the parts and working backwards to the beginning. Probably take forever, but time I've got! I'm not sure I said that quite right but you experienced craftsman will understand what I'm saying. Sure would make an interesting "builder's log".
Thanks again..........
PeterB
#7 Posted : 12 November 2017 23:52:47
BigGrin Hi Peter
I am doing the official build for the Conny if you look there its currently starting the second planking stage, so scrolling back on the pictures should give you an idea on where you want to go.
Link below:-
http://forum.model-space...aspx?g=topics&f=490
#8 Posted : 13 November 2017 00:05:09
Welcome to the forum Peter BigGrin hope to see some of your work on here.
#9 Posted : 13 November 2017 00:05:29
Hi Peter BigGrin
Which ever way you choose to go with your build, I look forward to seeing the results. Cool Cool
#10 Posted : 13 November 2017 08:19:49
The later instructions are currently being worked on and will be added to the web page as each is completed.
Welcome to the forum, hope you enjoy your stay with us Cool
#11 Posted : 13 November 2017 09:52:45
Welcome to the forum Peter, great to have you aboard..... Whichever direction you decide to go it will be very interesting following your build to see how it all turns out..... good luck with your project.....Cool Cool
#12 Posted : 13 November 2017 13:14:18
Welcome to the forum Peter BigGrin hope you sort a solutionBigGrin would look so cool as a dioBigGrin regards PhilCool
PeterB
#13 Posted : 13 November 2017 13:46:34
Rank: Newbie
In re waterline Constitution..
Thanks for the input, comments, suggestions, and warm welcome. I think I'm gonna like it here....
PeterB
Metal Mech
#14 Posted : 13 November 2017 15:21:58
Hey Peter welcome to the forum. I am the forum support team member for the USA side. I am here to help you with any questions or concerns about the forum and models kits. Feel free to contact me if you have any issues you need help with. If I don’t know the answer I will find it out for you.
As you can already see we have plenty of helpful and knowledgeable memebers on here that are always willing to help you as well. It’s a very fun and friendly place to be. I hope you enjoy your time here and look forward to seeing how your build progresses.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
This page was generated in 0.194 seconds.
