6 Pages <12345>»
Artesania 1/16 Fokker Dr.1 Build Options
#41 Posted : 05 November 2017 21:41:36
BigGrin Thanks for looking in everyone and your commentsCool
#42 Posted : 06 November 2017 15:38:57
Hi Andy.
looks a stunning build. great to see how they actually put the aircraft together.
Ian Cool BigGrin Drool
#43 Posted : 06 November 2017 21:57:07
BigGrin Thanks for looking in and your comments IanCool
#44 Posted : 06 November 2017 22:35:14
Nice work Andy, love all the detail it gives.
Chris Cool
#45 Posted : 07 November 2017 12:14:35
Great as always AndyBigGrin looks very impressive alreadyCool regards PhilCool
Sticky Wickett
#46 Posted : 07 November 2017 13:07:20
Top quality work as always Andy. Excellent!Cool
Phil W.
#47 Posted : 07 November 2017 20:12:51
BigGrin Thanks for looking in and your comments everyone its a great little kit to buildCool
#48 Posted : 08 November 2017 00:53:28
Loving the detail Andy, looks fab....Drool Drool
#49 Posted : 08 November 2017 21:49:38
BigGrin thanks for looking in and your comments AlanCool
#50 Posted : 12 November 2017 19:28:56
Some more progress.
The ply side panels and the top ply panel [ not fixed in place yet ] were shaped then undercoated and the first coat of brown added. Using the AL Wood Mask tool I proceeded to paint the grain onto the parts.
I found the best way to use the mask is to fix it onto the part using masking Tape and then spray your darker colour as per the instructions. The mask is only so big and will need to be repositioned on the part to prevent the spray line the trick is to leave a wavy line before you reach the edge of the mask, reposition and respray and hey presto no spray lines.
Once dry the side panels were fixed to the fuselage , the top section will be fitted later on in the build.
The next part of the build starts with the lower wing. I used a wood stain on the ribs and rib tapes and left the box spar natural. the construction is straight forward and the trailing edge is made from etch. Still some things to add like the etch leading edge and more tapes.
More soon
#51 Posted : 13 November 2017 09:17:36
Some lovely detail in this kit and the PE panel painted to look like wood looks great, seems that the wood stencil does the trick Cool
#52 Posted : 13 November 2017 12:37:25
Love the detail, great work Andy.
#53 Posted : 13 November 2017 12:53:08
Great job Andy, looks to be a nicely detailed kit.
#54 Posted : 13 November 2017 13:13:01
great work AndyBigGrin going to be a eye catcher when completeBigGrin regards PhilCool
#55 Posted : 13 November 2017 19:59:47
Very impressive. Love
WTG Andy. Cool Cool Cool
#56 Posted : 13 November 2017 21:01:07
Lovely job Andy, great use of the wood stencilBigGrin
tnequette
#57 Posted : 13 November 2017 22:15:28
Andy,
You really do incredible work. You are sorely tempting me in the build but over here we don't have the DeAg support as AL is easily bought. Are the kits EXACTLY the same?
Any way, can't wait to see the engine work.Drool
Tom
#58 Posted : 13 November 2017 23:10:01
Tom
Andy’s DR.1 kit is the AL kit, identical in every way including the box.
#59 Posted : 14 November 2017 23:36:43
BigGrin Thanks for looking in everyone and your comments all very much appreciated.
Its a very nicely put together kit and a joy to build the only extras are the etch wood grain panel, paint and wood stain for the ribs.Cool
#60 Posted : 26 November 2017 20:03:18
The brass etch leading edges were made up for the lower wing glued in place and then the wing tapes were added. After that the outer wing struts were added at either end of the wing along with the etch spar brackets for each one. The lower wing was then attached to the fuselage.
The mid-wing was made up in the same way as the lower wing but with a different trailing edge to go around the cockpit. This done the leading edges and tapes were added then the assembly was added to the upper fuselage. Some adjustment may be needed here to make sure the mid-wing sit's against the fuselage upper bars.
The last central rigging wire was attached to the front fuselage bar and then the front upper fuselage cover was added making sure the rigging wires exit in the correct places. the central upper wing struts came next then the two side cockpit shrouds were then added and last of all the ply rear fuselage cover.
Next we start the assembly of the twin machine gunsDrool Drool Drool Drool
More soon
6 Pages <12345>»
