stevegbr wrote:birdaj2 wrote:Very nice progress Steve.
Is that carpet supplied as part of the kit or is it something you have purchased as an upgrade? no tony, got it off facebook, a guy named mike lane, does the barcode magnetic reg plate as well. well pleased. Thanks for that Steve. As an add on he has done a top job with the design as you have in fitting it. Hope it all continues well. Happy Modelling
Have you got your issue`s yet steve  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Yes Phil. They arrived Monday mate. Will put photos on later.
here is issue 44. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
attached the two parts to the dash. stevegbr attached the following image(s):
here is issue 45. stevegbr attached the following image(s):
the led circuit is attached, then secured to the dash. stevegbr attached the following image(s):
the underneath showing the wires. stevegbr attached the following image(s):
clock panel pressed in cowl. stevegbr attached the following image(s):
here is issue 46. stevegbr attached the following image(s):
dashboard display fitted. stevegbr attached the following image(s):
instrument panel with the led board inserted. stevegbr attached the following image(s):
wires tidied up on the rear. stevegbr attached the following image(s):
here is issue 47 stevegbr attached the following image(s):
indicator stalks assembled. stevegbr attached the following image(s):
bracket to hold the steering column. stevegbr attached the following image(s):
Guest (12)
