issue 29 Options
johnboy3376
#1 Posted : 20 November 2017 14:35:36
Rank: Newbie
I have followed all of the advice here and I'm still seeing nothing but a white light when I do the test for Luke and Leia. I called customer service and they referred me to the boards. Not sure what to do.
tschwand
#2 Posted : 20 November 2017 15:12:17
If I remember correctly, if all you get is a white light, try putting in new batteries. If that doesn’t work, you need a new board. So then you need to call and ask for a replacement issue.
Metal Mech
#3 Posted : 20 November 2017 15:49:50
Hey I am the forum support member for the USA. Tschwands advice above is correct. Try fresh batteries. If that doesn’t work you need a new board. If that is the case pm me and I will get that straightened out for you.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
Archaeopterryx
#4 Posted : 24 November 2017 18:48:51
Rank: Newbie
I, too, am experiencing a bad projector. I only get the white light, and new batteries have not helped. May I PM you as well, Metal Mech?
Thanks!
Metal Mech
#5 Posted : 24 November 2017 19:39:44
Thanks!
Absolutely. I will get it sorted out for you.
This page was generated in 0.356 seconds.
