Joined: 19/11/2017 Posts: 41 Points: 135 Location: Marlow
I am new to this Forum, and would be very interested to know how many people on the forum have a disability that makes Modeling a bit more of an adventure than those lucky enough to have full abilities. I have Multiple Sclerosis which has left me with just my right hand to work with, this means that I have to think about ways of holding the parts Im working on. Although I build a lot of plastic kits to keep me occupied I find these large scale screw together models a great help as assembly just requires a good clamping system and a screw!!! Anyway as this is my first post I would very much like to hear from others on my subject Im on part 35 of the JaguarE type. Regards Tony
Welcome to the forum Tony. I hope you find the forum a helpful place to be, there is a lot of expertise here.
I'm sure there are many builders who would be interested in the methods you use to overcome your disability (whether disabled or able bodied) as well as others who would be glad to help with any particular problems that may arise for you.
I for one would love to see some examples of your work.
Welcome to the forum Tony  hope to see some pictures of your build  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Welcome to the forum Tony  hope your enjoying your Jaguar build so far. Al
welcome tony, would be great to see some photos of your work.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,413 Points: 22,549 Location: Northamptonshire, England
Welcome to the forum Tony, I look forward to seeing some of the work you have done soon. Mark Regards Markwarren (Mark) Admin
 Rank: Amateur Level 1  Groups: Registered
Joined: 29/04/2017 Posts: 38 Points: 120 Location: Wirral
Hello Tony
It sounds like you're getting on really well with the build. I found the wire wheel to be challenge enough with two working hands.
I haven't got a disability other than aging eyesight but I have found it a lot easier to use a different screwdriver with 8 interchangeable magnetic bits of different sizes, particularly for the frame. It has a wider shaft so easier to grip. I look forward to seeing pics of your build.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,865 Points: 17,747 Location: ipswich
Hello Tony. Welcome aboard.
There are quite a few build diaries of the E Type to peep at for ideas. If you get stuck, there's plenty of help here.
Roy.
Welcome aboard Tony, hope you enjoy your time with us and look forward to seeing some of your work..... Regards Alan
Welcome aboard Tony. Enjoy Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thank you all for the very warm welcome. I am having a great time building the E type which comes as a relief from my last E type which was from Monogram and took a lot of patience as the kit is very old, infact when I was in Holland in the 60s this kit was brand new, and only £8.00! With regard to methods I have a small hand vice which was built as an examination piece for an apprentice and I couldn't manage without it. I will try to put some pictures on the site if I can work out how to do it.
Welcome Tony, look forward to seeing your build progress. Hope you enjoy building it. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Tried getting pictures on the page but with no luck, Im using a Macbook which seems to make the job difficult. Anybody with advice would be welcome. I notice two images showing but they havent downloaded
Your pictures are way too big. Max image size is about 145kb Yours are around 2,000 - 2,500kb.
You need to resize them in a picture editing or paint program.
Roy.
 Welcome to the forum and enjoy your build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
roymattblack wrote:Your pictures are way too big. Max image size is about 145kb Yours are around 2,000 - 2,500kb.
Roy. Thanks Roy I must do some resizing asap
Hi Tony, a guide on how to resize and post pictures on the forum is available here http://forum.model-space....aspx?g=posts&t=244
The pics should be 600x450 pixels which should give you the correct file size for them to visible on the forum without members having to download them. Hope this helps Graeme
Well Ive read all of the info on resizing photos but most refer to windows, is there a trick i should know when using my Macbook? Tony
Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
Welcome to the forum Tony: I have a neck injury that will only allow a limited time to model while looking downwards, so most of my modeling is done standing up with a height extension on my bench to allow me to work looking straight ahead. not the easiest way to work, but better than nothing, one does what he can.
Welcome to the forum Tony...I hope that you enjoy your stay and look forward to seeing your build pictures... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
