38 Pages «<678910>»
Garth's Black Pearl Options
#141 Posted : 21 November 2017 18:57:28
Lovely work Garth, looks very effective.Love
Garth
#142 Posted : 22 November 2017 06:39:23
Hi Guys,
Thanks for looking in and leaving such inspiring comments.
I have been giving my wiring some thoughts and I think I have a better solution. BigGrin
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#143 Posted : 23 November 2017 14:37:43
Garth wrote:
Hi Guys,
Kind regards,
Garth
Hi Garth, check out small scale lights.com for reference. Might not be what you're after, but they're handy to know of for future projects.
Phil W.BigGrin
Garth
#144 Posted : 24 November 2017 10:34:04
Hi Phil,
Thanks for that. Will defiantly check it out.
Kind regards,
Garth
Garth
#145 Posted : 04 December 2017 06:10:01
Hi again Phil,
I had a good look at that website, they have really done their homework. I definitely recommend any body who wishes to illuminate their models to check them out.
My only problem is that living in South Africa, with an exchange rate of almost 20:1, compounded by an unreliable postal service, these items become are just too costly. I have to make do with what is locally available.
But, thanks again.
Kind regards,
Garth
Garth
#146 Posted : 04 December 2017 07:16:37
Hi All,
To add more light, I made 3 more lanterns.
I tried a different approach on the wiring this time. I used scrap ribbon cable recovered from an old PC hard drive. This worked much better than the armature wire.
In addition, I fitted a tiny piece of heat shrink around the LED to prevent it shorting on the lanterns body. As with the other lanterns, I applied a blob of clear silicone sealer to the back of the LED and pushed it into the lantern. It’s important to leave this to dry for a couple of hours.
This method worked much better, the entire assemblies seemed much tougher and there was no ‘flickering’ once all was soldered!!!
Whilst the soldering iron was out, I used the opportunity to neaten up the wiring, fit the input wires and the wires that will connect the second decks ‘Buzz Bars’.
Kind regards,
Garth
Garth attached the following image(s):
#147 Posted : 04 December 2017 09:09:01
Great looking lighting effects Garth, well done.....Drool Drool
#148 Posted : 04 December 2017 10:02:20
I really do like the lighting effects Gatth looks just like candle lanterns from your pictures.
#149 Posted : 04 December 2017 16:40:45
looks great GarthBigGrin the new wiring has made a differenceCool regards PhilCool
#150 Posted : 04 December 2017 21:33:53
Lovely work Garth, looks excellent BigGrin
#151 Posted : 04 December 2017 22:32:14
Looking brilliant, very atmospheric.
#152 Posted : 05 December 2017 01:14:06
Very nice Garth. Love it mate.
Chris Cool
Garth
#153 Posted : 08 December 2017 13:01:43
Hi Guys,
Thanks for looking in and for the kind remarks. It's really appreciated.
Kind regards,
Garth
Garth
#154 Posted : 11 December 2017 06:54:22
Hi All
Now for a bit of fun. I have always wanted to have some skeletons in the cells and I finally was able to get my hands on some suitable candidates.
To make the candle, I used a piece of 0.75mm fibre optic. I made a projector using some of off-cut styrene tube with a 3mm LED and the 0.75 Fibre Opric hot-glued into each end.
I cut the optic at an angle to look like a flame and used some old GW Yellow Ink to change the colour of the LED.
I made a table of sorts then drilled a 1mm hole through for the Fibre Optic.
The projector and wires are tacked to the underside of the deck with hot glue.
A note on gluing Fibre Optics. Do some tests first as most solvent based glues damage the Fibre Optic and it can snap. Use epoxy or hot glue to glue them.
Kind regards,
Garth
#155 Posted : 11 December 2017 13:32:44
Looks so coolDrool Drool great stuffLove Love regards PhilCool
#156 Posted : 11 December 2017 16:05:22
Excellent work Garth. Cool Cool
Love the fun element WTG.
#157 Posted : 11 December 2017 16:22:40
Lovely work Garth, putting some life and soul into it, looks great.BigGrin
#158 Posted : 11 December 2017 23:59:01
What a great addition Garth, looks amazing.....Drool Drool
Sticky Wickett
#159 Posted : 12 December 2017 15:20:45
Fantastic work Garth!Cool Those skeletons really bring the model to life. <ahem> Pardon the pun!LOL
Phil W.
Garth
#160 Posted : 22 January 2018 08:32:36
Hi Guys.
Thanks everybody for looking in and for the kind replies.
I've been out of circulation for a while, and seen as I drive a mouse for a living - I avoid the computer like the plague when I'm on leave.
Kind regards,
Garth
Guest (23)
38 Pages «<678910>»
This page was generated in 0.234 seconds.
