24 Pages «<89101112>»
L'Hermione Build Options
Sticky Wickett
#181 Posted : 30 November 2017 12:36:09
Very nice first coat of primer Alan!Cool Your preparation provides a great key for future coats.
Phil W.
#182 Posted : 30 November 2017 13:42:39
Great job with filler/sanding to get that result from the first primer coat, nice one.
#183 Posted : 01 December 2017 00:18:30
Phil/Graeme, thanks for looking in and your kind comments.... appreciated.....Cool Cool
#184 Posted : 01 December 2017 14:27:08
Outstanding work AlanDrool Drool is the sanding all by hand or do you use a electric sanding toolConfused regards PhilCool
#185 Posted : 01 December 2017 17:42:53
BigGrin Nicely done on the hull AlanCool
#186 Posted : 01 December 2017 23:29:10
Phil/Andy, thanks for looking in and your comments.. appreciated...Cool Cool
@Phil, filling and sanding down is all done by hand. Won't use any power sanders on any of the hulls I put together, they can take off far too much material in a very short period of time and that would prove to be disastrous... I prefer to be in control of the material I remove and start off with a course grade sandpaper...Cool Cool
As an update, the second primer coat has been applied and really there isn't much to see so will post again when the first layer of top coat goes on, hopefully this weekend sometime....Cool Cool
#187 Posted : 02 December 2017 10:52:41
That is some really good information on how to get a nice finish on the hull.
Lots and lots of hard work but i can see what you mean about putting in the effort pays off with a lovely result.
#188 Posted : 02 December 2017 12:21:35
Nice work Alan, for a first coat, thats a great sanding job,ThumpUp
#189 Posted : 02 December 2017 23:55:18
Thanks Tony/Mark, appreciate you looking in and your comments....Cool Cool
Happy to say stage 14 is now complete with the application of the top coat of paint. Two coats of top coat applied (off white) and now will be left to dry thoroughly before continuing.... Next task, more masking to be done as we start to paint the black, yellow and blue banding. Until then, happy modelling.....Cool Cool
#190 Posted : 03 December 2017 07:44:05
Strewth!! That is one heck of a finish Alan....Smooth as a baby's bot..Cracking job!! Drool
#191 Posted : 03 December 2017 08:44:59
BigGrin Wow that's one sweet finish Alan very smooth Cool
Martyn
daffy09
#192 Posted : 03 December 2017 16:26:13
Lovely work Alan. Have to agree with Jonny7, "smooth as a baby's bot". If mine turns out half as good, I'll be well satisfied, can't wait to see the black, yellow and blue go on her.
Happy building
David
#193 Posted : 03 December 2017 18:18:19
Cracking job Alan, you’ve definitely got than sanding down to a tee. ThumpUp
#194 Posted : 03 December 2017 19:10:08
BigGrin Nicely done now for all that loverly masking offLOL Cool
#195 Posted : 03 December 2017 22:45:03
Awesome work Alan, lovely paint job now for the masking lol.
Chris Cool Cool
#196 Posted : 03 December 2017 22:56:45
Fantastic finish Alan, great job.
Garth
#197 Posted : 04 December 2017 06:11:39
Hi Alan,
Awesome job on the sanding. Flawless!!!
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#198 Posted : 04 December 2017 09:10:26
Thanks to everyone for looking in and all your comments, appreciated....Cool Cool
#199 Posted : 10 December 2017 23:36:03
Onwards and upwards with the completion of stage 15. This has us masking and painting the black, yellow and blue strips along the hull, this is a lot more work than you would imagine. First job is to mask off the area for the yellow band. This doesn't have to be too accurate as we will be painting over the upper and lower edges of the strip, main thing is to ensure the strip is wide enough. Completely covered the lower hull, stern and bow areas to protect these areas from overspray. Inside the gun ports masked off too and protected the main deck. Yellow band was then painted and left to dry fully. Masking was then removed but left gun ports and stern gallery covered.
Next part was to mark off the area for the black band. The upper and lower edges were marked out using a waterline marker to the measurements outlined in the instructions. The lower edge of the yellow band was then sanded over using very fine sandpaper, this is so the seam doesn't show through when the black band is painted. Again masked off the upper and lower hull completely then the black paint applied, including the stern and bow area and left to dry thoroughly. Masking was then removed from the upper hull area.
Finally, masked off the upper hull area and painted the blue band. When happy, all the masking was removed and minor touch ups done. Hard part now will be to avoid marking the hull during the rest of the construction, a tall order so no doubt further touch ups will be needed as we progress.
That's it for now so until next time, happy building all....
#200 Posted : 11 December 2017 00:25:22
That is some very neat painting and what smart looking colours.
Guest (17)
This page was generated in 0.266 seconds.
