11 Pages «<23456>»
Vw Golf 2 GTI Tuned 1/8 Build Options
#61 Posted : 22 November 2017 11:53:00
It looks amazing.
Keep it coming...!
frah2o
#62 Posted : 23 November 2017 07:26:42
Yestrday i continued with the suspension.
To have the right height i need to cut the absorber. On the front axle i did the notching to the chassis (as like on my real GTI).
Watching the asbsorber i deciced to remove the spring. I try to self made the air bags of airride system. I'll take a Delta issue with fire extinguisher to use the tank for airride system: in my mind is to place the future tank in the trunk.
This week I'l cut the asborber and i'll paint in yellow like mine of my G.A.S. airride system.
I found also a self adhesive balck felt to cover the foot floor nad the trunk.
frah2o attached the following image(s):
frah2o
#63 Posted : 24 November 2017 07:33:11
Upholstery first step: Done!
I covered the floor matt and the under piece of central tunnel.
The next parts to trim are the rear seat base, the trunk and the trunk cover.
I placed the seat to see the global view.
With alu i'll try to sel made the brackets for seat.
#64 Posted : 24 November 2017 10:00:07
looking great thereBigGrin is that dolls house carpet you are using ? regards PhilCool
frah2o
#65 Posted : 24 November 2017 10:42:22
Hi Tiger, i bought on ebay from Uk seller 2 sheet of this trim, is the finest that i found. Best price in uk instead in Italy (hard to find this tipe of felt)
kpnuts
#66 Posted : 24 November 2017 12:31:11
Great work going on here, this will be sunning when finished.
frah2o
#67 Posted : 27 November 2017 08:25:11
This past weekend I was home to play with my daughter and while she slept or watched Peppa Pig and Masha & Bear I managed to go with the GTI.
I painted with xf16 the tank bands, a wash in black and then I fitted on chassis.
I started filling the tunnel junction lines, in the week after painting it, I should start with the template for the carbon.
I painted the handbrake in matt black and I painted the button in red as on the 20years edition. The shift lever needed some care: I painted the gear knob in x11 and gave a hand of black semigloss to try to simulate the leather.
Looking at the belt clips I noticed another difference with the original model: on golf 1, 2 and 3 the clip buttons are orange and not red .... I corrected them.
I painted the reinforcements on the front structs. A little black wash and finally I fitted the front bar.
On Saturday morning before I worked on the shock absorbers.
Shortened, refined and threaded.
I found some o-ring that could do my job to simulate the airride bags.
Test dry and finally painted in yellow.
Last night I finally fitted all and with the o-rings in place of the springs seems like a fully airride down.
The only work that was a bit difficult was the link of the steering bar. From box was straight, I folded it a little at a time to get the new angle due to the lowering and I also gave the right bend to the steering heads connected to the hubs. Try it all and work perfectly.
While the stabilizer bar dries (I made it red like Wiechers) I gave a bit of detail to the rims coloring the 80 bolts and the 16 bolts of the hub in gun metal.
#68 Posted : 27 November 2017 18:04:58
Enjoying seeing this come together BigGrin nice work.
#69 Posted : 27 November 2017 21:30:16
Another great update, looking fab......Cool Cool
frah2o
#70 Posted : 29 November 2017 07:53:47
Thanks too much for your comments mates, i really apprecciate this.
I started with carbon project.
This evening i covered half tunnel, this evening i think to finish it.
In my idea is to cover with carbon the dash, ans some detail in door trim.
frah2o
#71 Posted : 05 December 2017 07:37:04
Yesterday i finished the satbilizer bar. I painted it in red like the Wiechers.
I finished the work with carbon decal on tunnel, and also i started the carbon work on the side rear bracket of trunk trim
Finally i bought braided hose to made the brake lines.
#72 Posted : 05 December 2017 10:08:48
Top work, looking fab....Drool Drool
#73 Posted : 05 December 2017 10:26:32
Very smart looking model and fab details you are adding.
kpnuts
#74 Posted : 05 December 2017 11:04:20
So much good work going into this bravo.
#75 Posted : 05 December 2017 13:23:54
Great work, love the attention to detail you are putting in on this.BigGrin
#76 Posted : 05 December 2017 13:38:02
All the extra detail your adding is going to make this a show stopperDrool Drool great workCool regards PhilCool
#77 Posted : 05 December 2017 18:07:03
Great job on the carbon parts BigGrin liking how this is looking.
frah2o
#78 Posted : 20 December 2017 08:54:38
Thanks everybody for your comments mates.
In the past week I completed the carbon work on tunnel, it seems quite good.
With tamiya braided hose i made the new front brake lines
I also added new heatshield on exhaust line. In the future I'll made the final heatshield on the final silencer, but 'll wait the bodywork before to do this. I'n my project is to made a new single tailpipe like Bastuck Exhaust.
The last work is to trim the trunk, but i'll wait to fit on chassis because i'll do the airride system inside the trunk.
frah2o
#79 Posted : 18 January 2018 11:46:12
Seat fitted with self made alu bracket (just the recaro decal on the brackets)
Airride air tank fitted in the trunk.
Next step the rear seat (full black color) and the 4 point safety belts.
RM1
#80 Posted : 19 January 2018 11:16:21
Looking really good !!
Malc.
11 Pages «<23456>»
This page was generated in 0.327 seconds.
