106 Pages «<7778798081>»
#1561 Posted : 01 December 2017 14:29:05
ooh all those lovely shades of grey and a bit of whiteLOL great stuff Drool Drool Phil
Sticky Wickett
#1562 Posted : 01 December 2017 14:41:36
HahaLOL
< cue music with grey in the song title>
'Fade To Grey' by Visage and 'Grey Day' by Madness.
Thanks for looking in Phil!Cool
Phil W.
Sticky Wickett
#1563 Posted : 06 December 2017 22:57:51
Good evening from 'The Dockyard',
This weeks update of my U230 U-Boat build log continues with the painting of the compartments.
The attached photo shows the Aft Torpedo Compartment/Motor Room masked up ready for painting in the sky grey i mentioned last week. Prior to this i marked out a pencil guideline to mask too.
Sticky Wickett
#1564 Posted : 06 December 2017 22:58:56
Engine Room masked up in the same manner.
Sticky Wickett
#1565 Posted : 06 December 2017 23:01:26
This photo shows the Engine Room masked up, looking foreward. I used two different types of Tamiya masking tape; 6mm and a 3mm type which is suited to bending around curves.
Sticky Wickett
#1566 Posted : 06 December 2017 23:04:06
This photo shows two coats of sky grey applied to the Aft Torpedo Compartment/Motor Room. I was happy with the even coverage after two coats so i left it at that.
Sticky Wickett
#1567 Posted : 06 December 2017 23:05:04
The Engine Room also received two coats of the sky grey.
Sticky Wickett
#1568 Posted : 06 December 2017 23:07:45
I then moved onto what will become a cut away view of No.2 Battery Compartment.
This photo shows it masked up.
Sticky Wickett
#1569 Posted : 06 December 2017 23:08:49
Second coat being applied.
Sticky Wickett
#1570 Posted : 06 December 2017 23:10:19
This photo shows the masking tape being removed from the Aft Torpedo Compartment/Motor Room.
Sticky Wickett
#1571 Posted : 06 December 2017 23:13:56
There wasn't that much 'bleed through' when the masking tape was removed with a minimal amount of 'touching in' required.
Sticky Wickett
#1572 Posted : 06 December 2017 23:15:22
After I had 'touched in' any smudges.
Sticky Wickett
#1573 Posted : 06 December 2017 23:17:27
Looking aft into the Aft Torpedo Compartment.
I'm happy with the way the painting turned out, what with two colours and the numerous t-frames to mask around.
Sticky Wickett
#1574 Posted : 06 December 2017 23:23:25
That concludes this weeks update. Next week I will be completing the Engine Room and No.2 Battery Compartment plus any other painting I can fit in.
Thanks for looking in and your comments. Have a good week and happy modelling!BigGrin Cool
Phil W.
#1575 Posted : 06 December 2017 23:54:36
Nice update Phil, it’s all about the detail now. Great work.BigGrin
#1576 Posted : 07 December 2017 00:02:25
Very nice paintwork being done Phil, all looks great....Drool Drool
Sticky Wickett
#1577 Posted : 07 December 2017 00:07:35
Thanks Mark!Cool It's getting there. Another couple of weeks should see all of the compartments painted.
Phil W.
Sticky Wickett
#1578 Posted : 07 December 2017 00:11:34
Thanks very much Alan!Cool As I mentioned in a reply to Mark, another couple of weeks should see all of the compartments painted up. Got to be honest, it's taken a lot longer than I initially thought.
Phil W.
#1579 Posted : 07 December 2017 01:16:26
All that hard work is paying off with a great finish.
It might be taking longer than expected but you cannot rush perfection.
I cannot believe the incredible upgrade you have made to the base kit - its really exceptional.
Sticky Wickett
#1580 Posted : 07 December 2017 10:51:00
Thank you very much Tony!Cool When I initially thought about upgrading the model, I realised that if I was going to do it, then it had to be done to the best of my ability. Based on that, I committed myself to that fact that I was in it for the long-haul.Blink
Phil W.BigGrin
Guest (6)
This page was generated in 3.011 seconds.
