6 Pages «<3456>
Artesania 1/16 Fokker Dr.1 Build Options
DaDokta
#81 Posted : 05 December 2017 13:40:33
Such an amazing model and what a great build!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#82 Posted : 05 December 2017 21:47:42
Nytetrain
#83 Posted : 05 December 2017 23:33:32
Nice work Andy. Love Love So does the plane get skinned or is it displayed with the frame exposed?
Best Regards,
Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator
Finished builds: DeAgostini Toyota 2000GT
In the Stash: Losing count...
#84 Posted : 06 December 2017 20:58:28
BigGrin Thanks for looking in and your comments everyone, its a skeleton model so no skin to enable people to view what would normally be hidden by the doped linen covering. You could use clear solartex to cover it if you wished bit it is intended to be as seen.Cool
#85 Posted : 09 December 2017 17:42:42
Some more progress, The bungee's have been fitted to the tail skid and the undercarriage axle. The two grab handles by the tail were added along with the foot stirrup to aid getting into the cockpit.
Next the wheels were made up by shaping the etch cone sides and then painting the tyre's a light grey. The wheel hubs were added along with the spoke outers, I found with my hubs they were a little short so I added a couple of plasticard washers to the hub and then fitted the wheels to the axle.
More soon.
#86 Posted : 09 December 2017 20:25:02
Brilliant build Andy, looking fantastic.
#87 Posted : 10 December 2017 09:31:14
Excellent work Andy, what a great piece of kit.Love
#88 Posted : 10 December 2017 10:27:10
Great to see it up on its wheels, was the wheel spoking easy?
#89 Posted : 10 December 2017 10:51:22
Top work, a real class looking build....Drool Drool
#90 Posted : 10 December 2017 11:49:24
BigGrin Thanks for looking in and your comments everyone.
The spokes are easy enough to produce the cone effect I used the deluxe bending and rolling back plate that has a rubber mat designed to aid in bending etch along with the conical rolling tool.
All the above tools are available from good stockists but here is where I got mine from:-
https://www.scalemodelsh...html?infinite=true&
#91 Posted : 10 December 2017 12:13:29
Really excellent looking Model AndyDrool Drool regards PhilCool
#92 Posted : 10 December 2017 12:40:43
Excellent work Amdy, lovely looking model. Love the open frame work.
Chris Cool
#93 Posted : 10 December 2017 17:12:24
BigGrin Thanks for looking in everyone and your commentsCool
#94 Posted : 10 December 2017 17:25:51
The engine was made up next but first all the casting burrs were removed and then the engine was constructed. wires were added to the spark plugs and the etch rocker arms were added to the cylinder heads. The engine was then undercoated and once this was dry a coat of aluminium was put on.
These engines had a throw away oil system that literally squirted out the oil with the exhaust gases and the oil used was caster oil, to counter the laxative effects of the oil british pilots were given plum brandy to drinkLOL Blink .
The engine would therefore be covered in unburnt and burnt oil so a wash coat of burnt umber was added to the engine and then the decal added. The copper intake tubes were added next along with the brass push rods. The finished assembly was then added to the fuselage.
The cowl was next to be added along with the carved propellor this then finished the build.
Its a great kit with some challenges but the result more than speaks for itself as being a quality kit with a result worth displaying.
The last few pics show the progress on the figure its now assembled and has been undercoated.
#95 Posted : 10 December 2017 23:01:11
Nice work on the engine AndyBigGrin its been an interesting build to follow.
#96 Posted : 11 December 2017 21:51:17
BigGrin Thanks for looking in and your comments SpalCool
#97 Posted : 12 December 2017 14:03:26
Agree with Al total amazing build Drool Drool great to whatchCool regards PhilCool
#98 Posted : 12 December 2017 16:03:12
BigGrin Thanks for looking in Phil and your commentsCool
DaDokta
#99 Posted : 19 December 2017 09:57:32
Fantastic build!
I will spend my christmas-money on this kit!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#100 Posted : 19 December 2017 20:18:51
BigGrin Hi Walter thanks for looking in and your comments its a great kit and enjoy your build when you start herCool
Guest (6)
6 Pages «<3456>
This page was generated in 0.413 seconds.
