Such an amazing model and what a great build!Greetings, Walter
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 11/11/2015 Posts: 278 Points: 807 Location: Minneapolis, Minnesota USA
Nice work Andy.  So does the plane get skinned or is it displayed with the frame exposed? Best Regards, Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator Finished builds: DeAgostini Toyota 2000GT In the Stash: Losing count...
 Thanks for looking in and your comments everyone, its a skeleton model so no skin to enable people to view what would normally be hidden by the doped linen covering. You could use clear solartex to cover it if you wished bit it is intended to be as seen. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more progress, The bungee's have been fitted to the tail skid and the undercarriage axle. The two grab handles by the tail were added along with the foot stirrup to aid getting into the cockpit. Next the wheels were made up by shaping the etch cone sides and then painting the tyre's a light grey. The wheel hubs were added along with the spoke outers, I found with my hubs they were a little short so I added a couple of plasticard washers to the hub and then fitted the wheels to the axle. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Brilliant build Andy, looking fantastic.
Excellent work Andy, what a great piece of kit. Mark Regards Markwarren (Mark) Admin
Great to see it up on its wheels, was the wheel spoking easy?
Top work, a real class looking build.... Regards Alan
 Thanks for looking in and your comments everyone. The spokes are easy enough to produce the cone effect I used the deluxe bending and rolling back plate that has a rubber mat designed to aid in bending etch along with the conical rolling tool. All the above tools are available from good stockists but here is where I got mine from:- https://www.scalemodelsh...html?infinite=true&
Really excellent looking Model Andy  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Excellent work Amdy, lovely looking model. Love the open frame work.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Thanks for looking in everyone and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The engine was made up next but first all the casting burrs were removed and then the engine was constructed. wires were added to the spark plugs and the etch rocker arms were added to the cylinder heads. The engine was then undercoated and once this was dry a coat of aluminium was put on. These engines had a throw away oil system that literally squirted out the oil with the exhaust gases and the oil used was caster oil, to counter the laxative effects of the oil british pilots were given plum brandy to drink  . The engine would therefore be covered in unburnt and burnt oil so a wash coat of burnt umber was added to the engine and then the decal added. The copper intake tubes were added next along with the brass push rods. The finished assembly was then added to the fuselage. The cowl was next to be added along with the carved propellor this then finished the build. Its a great kit with some challenges but the result more than speaks for itself as being a quality kit with a result worth displaying. The last few pics show the progress on the figure its now assembled and has been undercoated. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work on the engine Andy  its been an interesting build to follow. Al
 Thanks for looking in and your comments Spal Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Agree with Al total amazing build  great to whatch  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Thanks for looking in Phil and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Fantastic build!
I will spend my christmas-money on this kit!Greetings, Walter
 Hi Walter thanks for looking in and your comments its a great kit and enjoy your build when you start her Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
