13 Pages «<45678>»
Schlachtschiff Scharnhorst 1:200 (69/140) Options
greyhawk
#101 Posted : 13 December 2017 10:24:07
Scharnhorst Issue 22
We finally get to take a break from roof related shenanigans and deal with the bow and stern of the ship instead.
For these we receive 2 plastic mouldings each which are epoxy-glued together and onto the ends of the hull. This is where the decision to use MDF to form the hull starts to make sense, because fit is absolutely perfect. These parts will make the planking of the hull (should we eventually start it at some point) infinitely easier. I'm usually not a big fan of plastic, but for these sections it makes things so much easier that I'm ok with it. Other options how these sections are done in other ships of this type are ceramic prefabs (prone to break, usually major fit issues) or building up the sections with layered plates of wood then sanding that block smooth (torturous work that usually ends in less than satisfying results)
#102 Posted : 13 December 2017 16:22:35
They look very well detailed as wellBigGrin great stuff BigGrin regards PhilCool
#103 Posted : 13 December 2017 21:18:38
Making great progress, all is looking good....Cool Cool
Sticky Wickett
#104 Posted : 14 December 2017 13:50:09
Progressing nicely Greyhawk!Cool
Phil W.
#105 Posted : 14 December 2017 16:29:06
Looking good. BigGrin
Those bow and stern pieces will save a lot of sanding.
Cool Cool Cool Cool
#106 Posted : 14 December 2017 21:56:50
A similar idea to the U-96, combining wooden planking with plastic sections and mdf frame. It worked well on the U-96.
greyhawk
#107 Posted : 20 December 2017 13:51:22
That's right. It's very close in design to the U96 for now.
Scharnhorst issue 23
Back to roofs. This time we receive the first two upper deck plates. Those are just loosely laid down on the hull for now. The designers surprise me again, but this time in a positive way. There are cutouts in the plates to simply stick the deck structures into. Proper Fit and sit of the deck structures is usually a huge pain in the behind so this solution is nothing short of genius.
greyhawk
#108 Posted : 27 December 2017 10:19:44
Scharnhorst issue 24
The next two deck plates arrive and are put in place loosely for now. Note the middle deck structure is the wrong way around because I'm dumb and should be turned around 180 degreees. Good thing that nothinng is glued yet.
#109 Posted : 27 December 2017 10:29:10
Looking good, as for the wrong way round, most of us have done it at some stage in a model.LOL
#110 Posted : 27 December 2017 11:52:13
She's looking good. Always good to spot the mistakes before glue is applied, as Mark says, we have all done it.
Gaeme
#111 Posted : 27 December 2017 14:16:46
Great looking modelBigGrin can`t wait for more Drool regards PhilCool
daffy09
#112 Posted : 27 December 2017 15:20:16
She's coming along superbly now. Looking forward to next update
Happy building
David
#113 Posted : 27 December 2017 17:34:20
Its looking the part now.
I think those injection moulded bow and stern sections are very good.
#114 Posted : 28 December 2017 01:52:40
Looking top notch, love watching Warship builds got a few to do but not just yet. Your doing a grand job on her.
Chris Cool Cool
greyhawk
#115 Posted : 03 January 2018 10:40:32
Thanks everyone
Scharnhorst issue 25
The last deck plate is delivered and all of them are now fixed to the hull. Small tabs on the cutouts and edges make it easy to properly align the plates.
DaDokta
#116 Posted : 03 January 2018 11:29:32
Huge model! Nice work!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
greyhawk
#117 Posted : 10 January 2018 10:40:49
Danke, Walter :-)
Scharnhorst issue 26
With the deck plates in place this is the perfect time to finally start planking the hull....
... so instead we start kitting out the upper deck structures. The middle deck structures curved sections are covered with brass and for the first time it becomes clear why the layered "multi-roof" approach was taken for these. Any portholes instantly become actual holes, no need to fake things with paint or opening them up with a drill. It's pretty ingenious.
We also build four ventilation system (?) thingys, to be installed at a later date.
#118 Posted : 10 January 2018 14:18:04
Nice progress Greyhawk, all looking good.....Cool Cool
#119 Posted : 10 January 2018 15:23:13
Wow that is a big ship.What is the length? Looking great
#120 Posted : 10 January 2018 15:48:35
It`s a bit weird not planking and starting to add the etch Blink still looks excellentDrool Drool regards PhilCool
13 Pages «<45678>»
This page was generated in 0.618 seconds.
