24 Pages «<1011121314>»
L'Hermione Build Options
#221 Posted : 18 December 2017 13:30:37
Loving the contrast of colours on this, great job Alan.
#222 Posted : 18 December 2017 13:32:38
Nicely done, gosh that red is bright, recon all the crew had sun glasses to work on her πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜Ž
β€œWhenever you find yourself on the side of the majority, it is time to pause and reflect.”
#223 Posted : 18 December 2017 15:16:30
Great Work AlanBigGrin pleasure to watchDrool Drool regards PhilCool
#224 Posted : 18 December 2017 19:16:38
BigGrin Looking good AlanCool
DaDokta
#225 Posted : 19 December 2017 09:51:08
Great Job on the gunports, Alan!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#226 Posted : 19 December 2017 10:06:26
Doing a great job Alan, Those nice clean lines and gunports are awesome.
Chris
#227 Posted : 19 December 2017 10:50:29
Thanks to all who have looked in, very much appreciated.....Cool Cool
@Jase, wait till later, there is a lot more of the red to go on yet.....BigGrin BigGrin
#228 Posted : 20 December 2017 00:22:18
Today I managed to complete stage 17 where we add 2 x 2mm shaped strips to be base of the bulwarks. For this stage it is recommended you shape the two strips using the Micro Shaper set available as an optional extra from the online shop. There are two sets, Ref 27300 and 27301. For this stage we require the centre shaper from set 27300....
http://www.model-space.c...b/micro-shaper-set.html
Once the two strips have been shaped I then stained them using a medium oak woodstain. Cut the strips to size and when happy with the fit I then mitred the ends to make neat joins around the ribs.
Next stage we start assembling some of the cannons so until then, happy building all.....
DaDokta
#229 Posted : 20 December 2017 08:08:27
Nice update, Alan! Looking good!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Sticky Wickett
#230 Posted : 20 December 2017 10:18:43
Very neat work Alan, looking really good!Cool I might have to invest in some shapers myself. They look really handy.
Phil W.
#231 Posted : 20 December 2017 15:17:31
Lovely work AlanBigGrin the Red is really bright Cool regards PhilCool
daffy09
#232 Posted : 20 December 2017 20:55:56
Lovely bit of detailing there Alan. This build is starting to show it's potential even at this early stage.
Happy building
David
#233 Posted : 20 December 2017 23:18:17
loving this definitely a kit to get I think
#234 Posted : 21 December 2017 06:21:50
Just spent a very enjoyable time reading this build diary Alan.Fabulous work
#235 Posted : 24 December 2017 01:13:55
Thanks again to everyone who looked in and for the kind comments....Cool Cool
Even though the run up to xmas is proving to be the usual busy time am happy to say I still found some time to progress the build a little further.. Next stage has us assembling cannons and started by removing the ply parts from their fret and cleaning all the cut edges from burnt ash. Glued the base and carriage sides in place ensuring they were set correctly and left to dry. Then turned the carriage over and using a small round file, created the two channels in the base to accommodate the wheel axles...
Axles are cut from 0.8mm brass wire, cut into 20mm lengths and glued into position centrally using superglue gel. Glued the wheels in place, gluing the wheels to the sides of the carriage and once set, the axles were then trimmed and filed to leave them protruding slightly. Word of caution here, when trimming the axles ensure you wear eye protection as the cut ends can fly off with great speed and cause serious injury to your eyes that would definitely ruin your day.....
Glued the small triangular gun support in position and once done repeated the whole process until I had 10 identical carriages... Took the 10 cannons and as with any castings, filed and cleaned away any cast lines and imperfections. Inserted cocktail sticks to aid painting.
Next step is to prime everything ready for painting so until next time, happy modelling.....Cool Cool
#236 Posted : 24 December 2017 01:21:32
BigGrin Some fun going on with those small gun carriages but looking good as alwaysCool
#237 Posted : 24 December 2017 07:30:38
BigGrin Cracking job on the gun carriages Alan Cool
Martyn
#238 Posted : 24 December 2017 09:44:04
That is looking a very neat and tidy build.
Artesania put together a very nice kit in this one with some really nice parts and details.
#239 Posted : 25 December 2017 00:03:36
Thanks for the comments guys, appreciated as always.....
@Andy, the carriages are quite small and fiddly.... and these are the big ones....BigGrin BigGrin .. Got a load of smaller ones to do yet....all good fun though....
giant242
#240 Posted : 26 December 2017 14:21:40
Rank: Amateur Level 1
Such beautiful work! I am so much in awe of your skills and talent. What a pleasure to follow your build, thank you for sharing.
have fun jess
Guest (20)
This page was generated in 0.236 seconds.
