 Rank: Newbie  Groups: Registered
Joined: 13/12/2017 Posts: 4 Points: 12 Location: Hershey
I am new, got the 1st 4 issues last week. The LED unit refuse to work. I used new Duracell batteries.
Hi and welcome to the forum , I would contact C/S for a replacement. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The parts ship on Wednesday. Looking forward to 5 to 8.
Joined: 30/05/2017 Posts: 29 Points: 93 Location: USA
Hey Belchfire. I'm a newbie too, but just wanted to share my embarrassing moment with you, as it may solve your problem. I worked issue 1 and my LED wouldn't light up either. I went so far as to pull out my ohm meter, testing voltages, and was in the process of disassembling the battery pack to resolder it, when I turned it over and discovered the on/off switch. One quick flip, and the LED came to life. Current Builds: R2D2, Millenium Falcon
Way ahead of you. Not the problem.
The replacement test board didn't solve the problem. I called and told them I finally used straight pins in the clips of my ancient Heathkit multimeter to test the battery box leads. The black wire wasn't connected inside. I called Modelspace, and they said the replacement would arrive in 2 weeks. 3 days later, it arrived along with issues 4-8. The LEDs work, and I'm reading each magazine before I do the tiny bit of assembly. Tomorrow, I do #5, more lights!
Glad you got it sorted out. If you ever have issue getting things sorted feel free to let me know and I can help. DeAgostini kit builds:
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,271 Points: 22,120 Location: Northamptonshire, England
Welcome to the forum, glad to see you getting started. I hope to see some pictures soon. Mark Regards Markwarren (Mark) Admin
