51 Pages «<2627282930>»
DaDokta`s Build Options
DaDokta
#541 Posted : 19 December 2017 09:59:51
Thanks guys!
Next i added all the fittings of the quarterdeck.
I produces some additional kevels not mentioned in the instructions.
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#542 Posted : 19 December 2017 11:57:47
Great update Walter, am loving your build.....Drool Drool
DaDokta
#543 Posted : 19 December 2017 12:07:58
Thanks Alan!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#544 Posted : 19 December 2017 12:30:39
Another superb update Walter, looking great.
#545 Posted : 19 December 2017 12:30:50
Very neat and tidy , excellent work.ThumpUp
Gibbo
#546 Posted : 19 December 2017 15:28:00
Hi Walter
The Kevels are a great addition
Paul
gingerale75
#547 Posted : 20 December 2017 00:03:55
Hi Walter,
Your build looks beautiful.
Laszlo
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
DaDokta
#548 Posted : 20 December 2017 08:13:49
Thanks guys! Much appreciated!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
z8000783
#549 Posted : 20 December 2017 10:26:48
Groups: Unapproved
Nice work as ever, Walter.
DaDokta
#550 Posted : 28 December 2017 11:53:39
Thanks you John!
The next project was the companionway - which turned out to be a small scale model of it`s own.
First i made the stairs - which went well this time.
Then i made the base out of various wood-strips - stained in walnut.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#551 Posted : 28 December 2017 11:55:38
Next were the pillars.
I used the provided pillars and added small pieces of a 2x2mm Strip on both Ends - a very fiddly task!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#552 Posted : 28 December 2017 11:56:32
The pillars were attached and connected with pieces of 1x1mm strips.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#553 Posted : 28 December 2017 11:58:51
Next came the handrails!!
I wanted to form them as in the original.
That meant to build each rail out of four pieces of 1x1 strips, connected in various angles.
It took me some hours to get it right!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#554 Posted : 28 December 2017 12:00:35
For the round heads of the pillars i tried different carvings - and finally had the idea to use some spare cannonballs - which had the exact right size!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#555 Posted : 28 December 2017 12:02:08
Finally i added the brass rings for the cannons.
The Quarterdeck is now finished!!
Next comes the poop-deck!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#556 Posted : 28 December 2017 12:12:07
Very nice work Walter.
That is a very neat idea to use the cannon balls as decoration on the railings.
#557 Posted : 28 December 2017 12:25:47
Great work WalterBigGrin excellent as alwaysDrool Drool regards PhilCool
#558 Posted : 28 December 2017 23:43:52
You're doing a fab job with her Walter, loving it....Drool Drool
#559 Posted : 29 December 2017 00:36:35
Looks great as always Walter Cool
#560 Posted : 29 December 2017 01:31:34
Nice work Walter, looks great.
Chris Cool
Guest (13)
This page was generated in 1.456 seconds.
