35 Pages «<7891011>»
Laszlo For's Diary Options
gingerale75
#161 Posted : 19 December 2017 23:59:14
After couple of days pause some work done:
Issue 69:
- Octagon on fore topmast completed and tapered
- Bottom of the topmast also carved to octagonal
- Hand mast and rope guide made
- Rope guide glued to mast cap and painted black
- Hand mast and topmast also painted
gingerale75 attached the following image(s):
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
#162 Posted : 20 December 2017 00:30:23
Looking good....Cool Cool
#163 Posted : 20 December 2017 02:10:57
Looks like some fiddly work there. Blink
All looking very accurate and coming together very well.
Cool Cool Cool Cool
Keep up the good work and looking forward to your next update.
DaDokta
#164 Posted : 20 December 2017 08:14:42
Your building-speed is amazing! Good update!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#165 Posted : 20 December 2017 09:19:36
Taking shape fast, well done Cool
z8000783
#166 Posted : 20 December 2017 10:28:47
Groups: Unapproved
You are certainly moving on. Well done Laszlo.
gingerale75
#167 Posted : 20 December 2017 23:38:08
Hello Shipmates,
Thank you for the positive comments.
Little work done today by completing Issue 69:
Fore topmast, hand mast and mast cap assembled and glued onto the fore mast and mast top assembly.
Today I also posted a concern/question regarding the rigging of the blocks to the yards and topgallant masts.
Could you please have a look and give me your opinion/advise?
See link to my post:
http://forum.model-space.co.uk/default.aspx?g=posts&t=25286
Thanks
Happy building!
Laszlo
gingerale75
#168 Posted : 21 December 2017 20:07:14
Today's work so far on Issue 70:
Fore topgallant mast tapered.
I upgraded the method what I used for tapering the studdingsail booms and showed in this post:
http://forum.model-space.co.uk/default.aspx?g=posts&m=263291#post263291
As the diameter of the topgallant mast is too big for the chunk in my Dremel I used my pillar drill with the same technique to wrapping sandpaper around the mast and moving it up and down to shape the perfect taper.
Basically it works like a vertical lathe.
The result is beautiful... I wish I was used this method for the main mast, would have been much quicker.
With this method I completed the tapering on the fore topgallant mast (incl. the step in it) within 15 minutes.
After tapering completed I made the octagonal hounds, also the octagonal carving at the bottom section.
Holes drilled, bead glued to top.
The mast and mast cap painted black.
Topmast cross trees glued in place and painted black.
Will carry on rigging and assembling the parts later on today, after the paint dried.
Happy building!
Laszlo
gingerale75
#169 Posted : 22 December 2017 01:55:34
Busy day today, Issue 70 finished:
- Topgallant mast with mast cap assembled to the fore topmast.
- Brackets and cradles fitted
- All rigging blocks fitted.
With this now the fore mast fully completed, will be test fitted to the hull tomorrow.
Two masts done (main and fore), two to go (mizzen, bowsprit) BigGrin
Happy building!
Laszlo
#170 Posted : 22 December 2017 09:32:17
You make that mast tapering sound easy but it looks difficult to me. You know what your doing though and your results are very nice.
Hope it all continues well.
#171 Posted : 22 December 2017 09:40:35
Great workmanship, and the result show what a beautiful job you have done.ThumpUp
gingerale75
#172 Posted : 22 December 2017 14:33:50
As promised, today I test fitted the fore mast to the hull together with the main mast.
Next to the ship is the main yard on the bench.
Isn't it looking great? Cool
Happy building!
Laszlo
gingerale75
#173 Posted : 23 December 2017 15:04:01
Started to work on Issue 71:
With the same technique with my pillar drill I tapered the fore yard to the required diameter.
It was a bit more challenging as the yard is longer than the topgallant mast, hence I had to turn the upper part of the drill away from the base to provide a bit more space.
Also after one end is tapered it was a bit more tricky to hold the tapered end in the chuck vertical but I managed to do it, resulting nice and equal tapering on both ends.
Happy building!
Laszlo
#174 Posted : 23 December 2017 15:33:09
You are a very skilled modelerBigGrin great stuffBigGrin regards PhilCool
#175 Posted : 23 December 2017 18:00:25
Very nice looking model you are putting together.
All looks so precise and neat.
gingerale75
#176 Posted : 23 December 2017 23:38:38
Further work today in Issue 71:
- Octagonal section added to fore yard
- Slings and bands added
- Six footrope supports made, again I used my own invention from thread as they are made from ropes on the real ship, not brass as in this kit. See details on this on my earlier post if you're interested:
http://forum.model-space.co.uk/default.aspx?g=posts&m=263336#post263336
I had to stop for today as my fingertips are covered with superglue, as a result of making the footrope supports. Laugh LOL
Happy building!
Laszlo
gingerale75
#177 Posted : 24 December 2017 18:09:07
Hi Shipmates,
First of all, I'd like to wish Merry Christmas to all of you, who are occasionally or regularly reading my build diary.
Some work still done today on Issue 71:
- Studdingsail boom irons fitted
- Footrope supports rigged to the yard
- Yard painted black.
I'm note sure why Blink but I left the irons unpainted, even if the magazine saying to be painted.
I also done it this way on the main yard, maybe I though it's better to show that they are made from metal.
Happy building!
Laszlo
#178 Posted : 24 December 2017 21:30:39
Very nice work.
You are rwally good at getting your tapering nice and even across either end of these parts.
#179 Posted : 25 December 2017 00:16:32
Very nice work, coming along very nicely....Cool
gingerale75
#180 Posted : 25 December 2017 00:54:52
Further work done on Issue 71 while waiting for Santa.
No sign of him so far... LOL LOL LOL LOL
One side of the fore yard fully rigged.
Happy building!
Laszlo
Guest (10)
This page was generated in 0.323 seconds.
