Thanks guys!
Next i added all the fittings of the quarterdeck.
I produces some additional kevels not mentioned in the instructions.DaDokta attached the following image(s): Greetings, Walter
Great update Walter, am loving your build..... Regards Alan
Thanks Alan!Greetings, Walter
Another superb update Walter, looking great.
Very neat and tidy , excellent work. Mark Regards Markwarren (Mark) Admin
Hi Walter The Kevels are a great addition Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Walter, Your build looks beautiful. Regards Laszlo Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Thanks guys! Much appreciated!Greetings, Walter
Nice work as ever, Walter.
Thanks you John!
The next project was the companionway - which turned out to be a small scale model of it`s own.
First i made the stairs - which went well this time.
Then i made the base out of various wood-strips - stained in walnut.DaDokta attached the following image(s): Greetings, Walter
Next were the pillars.
I used the provided pillars and added small pieces of a 2x2mm Strip on both Ends - a very fiddly task! DaDokta attached the following image(s): Greetings, Walter
The pillars were attached and connected with pieces of 1x1mm strips.DaDokta attached the following image(s): Greetings, Walter
Next came the handrails!! I wanted to form them as in the original.
That meant to build each rail out of four pieces of 1x1 strips, connected in various angles.
It took me some hours to get it right!DaDokta attached the following image(s): Greetings, Walter
For the round heads of the pillars i tried different carvings - and finally had the idea to use some spare cannonballs - which had the exact right size!DaDokta attached the following image(s): Greetings, Walter
Finally i added the brass rings for the cannons.
The Quarterdeck is now finished!!
Next comes the poop-deck!DaDokta attached the following image(s): Greetings, Walter
Very nice work Walter. That is a very neat idea to use the cannon balls as decoration on the railings. Happy Modelling
Great work Walter  excellent as always  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
You're doing a fab job with her Walter, loving it.... Regards Alan
Looks great as always Walter Al
Nice work Walter, looks great.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Guest (25)
