12 Pages «<9101112>
Gils HMS Victory - Cross Section Build Options
#201 Posted : 20 December 2017 18:49:25
That looks wonderful.
Such a nicely detailed model and you have put it all together so well.
#202 Posted : 20 December 2017 19:51:27
Beautiful work on this Gil, I'll be spending a lot of time checking out your diary next year - I chose this kit as my prize!BigGrin
Robin.
#203 Posted : 20 December 2017 20:26:14
Looking great with some paint on her Gil BigGrin
DaDokta
#204 Posted : 21 December 2017 08:27:03
Fabulous build! Looking great!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#205 Posted : 21 December 2017 09:55:15
Looking good Gil, very nice indeed....Drool Drool
#206 Posted : 21 December 2017 11:40:28
Nice work Gil, loving the additional points of detail being added. Are you going to copper plate the lower hull? If so CMB have the Amati 1/172 nail marked tiles...
http://www.cornwallmodel...mati-copper-plates.html
Also the Caldercraft 1/72 nail marked tiles (supplied with their HMS Victory kit)..
http://www.cornwallmodel...g/caldercraft83525.html
Cool
#207 Posted : 21 December 2017 12:06:48
Very nice indeed, certainly taking shape .BigGrin
GilShapley
#208 Posted : 23 December 2017 13:06:07
Change of plan for the hammocks. My original idea produced hammock rolls that where too big for the smaller hammock cranes. So plan B. I am now using a cocktail stick as a base rather than the piece of dowel. (Useful things those cocktail sticks BigGrin ) This produces a roll/Hammock that will fit in the smaller hammock cranes and also will stack in the larger cranes/netting.
Current Build:-
#209 Posted : 23 December 2017 13:34:11
BigGrin Nice work GilCool
GilShapley
#210 Posted : 23 December 2017 16:20:43
Think I might have gone overt the top with the number of barrels required
I found I did not have a steady enough hand to paint the black rings on the barrel so my answer was to use the side of the point of a black permanent marker, Sharpie fine point permanent marker works fine and dries quickly (Other permanent markers are available)
Current Build:-
#211 Posted : 23 December 2017 16:35:03
Looks good Gil. Cool
Those Sharpies are great, I`ve used them on many occasions.
#212 Posted : 24 December 2017 00:20:49
First class work Gil, looks fabulous......Drool Drool
#213 Posted : 24 December 2017 01:02:06
Great update GilBigGrin nice idea for the hammocks and love the barrels.
GilShapley
#214 Posted : 28 December 2017 22:25:30
Hammocks - the end
Of all the parts of the build so far I found this to be the most mmmm frustrating is a good word.
I have already described my system for the hammocks so it was on to the Hammock Cranes. The holders are straight forward to install. I used some brass rods to insert into the holes in the cranes that I had in my stash rather then try to straighten out the brass supplied.
Onto the netting and the most frustrating part so far.
Here is my eventual method.
1) Using a piece of A4 paper mark out the size of the netting supplied
2) Measure the 3 different sizes of netting required
3) Mark out the five pieces required ( two of them will be the same ) This will ensure you have sufficient netting to make all of the 5 netting's required.
4) Cut out the templates and use these to fine tune the size of the netting you will require. These templates are much easier to fold and cut and if you make a mistake it will not matter. Once you are happy with the fit use the template to assist with the cutting of the netting.
5) Page 18 picture 9 in the magazine shows the method I used to place the netting.
6) I tried several methods and in the end I found the best method to attach the net to the hammocks was to use my needle threader to pull the thread through the net rather than try to pull it with a needle. Push the threader through the net in the required place inset the thread and pull. Try it for yourself.
Once the netting is in place you can add the hammock rolls. I made them of different sizes as required
Some pictures attached
Current Build:-
GilShapley
#215 Posted : 28 December 2017 22:33:39
Pictures for my post
Current Build:-
#216 Posted : 28 December 2017 23:09:24
Great job Gil, looks fantastic - a credit to you.
#217 Posted : 28 December 2017 23:14:21
Gil
Lots of hard work and patience needed to get all those bed-rolls in place but really neat finish you have made with yours.
#218 Posted : 28 December 2017 23:57:52
You've been rewarded by your patience Gil, looks great.....Cool Cool
#219 Posted : 29 December 2017 00:38:56
Very neat and tidy Gil BigGrin great job.
#220 Posted : 29 December 2017 01:24:26
Great work Gil, Looks awesome mate.
Chris Cool
12 Pages «<9101112>
This page was generated in 0.226 seconds.
