Rabbet Lines Options
pocketshaver
#1 Posted : 30 December 2017 02:21:40
Rank: Beginner Level 3
They exist in the real world and in most model plans.
But what has me curious is that very few people here seem to use them in their photo build logs.
I haven't seen anyone using the "false rabbet" using a piece of strip to do the job and eliminate carving.
SO are they actually necessary?
#2 Posted : 30 December 2017 08:15:16
BigGrin Hi m8 I have used the rabbet line on my Soliei Royal but this is the first time I have done so as I plank the keel after the second hull planking which covers up the gap between the garboard plank and the keel Cool
Hope this helps
Martyn
#3 Posted : 30 December 2017 09:51:01
Generally unless a kit has designed one in to put one in yourself is a lot of effort for arguably not a lot of return. I personally see the risk of damage and the time required when comparing against simply putting a chamfer on a plank as not adding up. You would also need a wider first plank if doing this.
If you are building an admiralty model and want to be true to the original construction methods then I totally get it.
pocketshaver
#4 Posted : 31 December 2017 02:38:27
The funny thing is, its become a mandatory thing of misery on some modeling sites.
#5 Posted : 31 December 2017 09:22:19
Confused There are several sites that if you don't put one in you seem to get a lot of frowny faces Mad Mad Mad for some reason, but I always say it's your model and yours alone and as long as you are happy with it that's the main thing Cool
Martyn
#6 Posted : 31 December 2017 09:34:55
Martyn
absolutely
This page was generated in 0.049 seconds.
