5 Pages <12345>
Al's Robi Options
#41 Posted : 30 December 2017 17:30:55
Pack 8
This time we use the parts from last month and this months together to make Robi's foot and ankle joints, his lower leg and his knee frame.
Thanks for looking
#42 Posted : 31 December 2017 00:22:43
He's growing with every update, looking good Al.....Cool Cool
#43 Posted : 31 December 2017 02:13:48
you are getting a leg up on this build Al Laugh Laugh Laugh Laugh
#44 Posted : 31 December 2017 15:50:12
BigGrin Thanks for looking gents,almost halfway through the build now.
stevegbr
#45 Posted : 31 December 2017 16:25:44
great to see you are on the foot now al, it looking like its coming together now. are you signing your name on his foot sole. LOL LOL LOL LOL
#46 Posted : 31 December 2017 21:25:56
LOL LOL No I think I will give that a miss Steve LOL
#47 Posted : 02 February 2018 22:36:39
Pack 9
Halfway through the build now and Robi is gradually taking shape. In this pack another servo is tested and fitted to complete a leg and another is prepared for use in pack 10. This month Robi also gets his pair of polishing shoes LOL
AL
#48 Posted : 03 February 2018 01:49:25
Looking good Al, very soon you'll be able to say 'It's Alive, It's Alive'.....BigGrin BigGrin BigGrin
#49 Posted : 11 March 2018 19:01:02
Thanks Alan BigGrin may be a while yet.
Pack 10
Here we receive the battery for Robi and start to assemble his left foot and ankle joint.I have added a pic of how Robi looks at this stage BigGrin
#50 Posted : 03 April 2018 16:45:09
Pack 11
Not a great amount to do this month apart from connecting the power cable to the rear panel and then attaching the power cable and battery to the power board before plugging the charger in and charging the battery.
#51 Posted : 03 April 2018 18:15:19
BigGrin looking goodCool
#52 Posted : 03 April 2018 22:33:38
The end is in sight Al, looking good....Cool Cool
#53 Posted : 03 April 2018 23:17:16
Just catching up with your progress, he’s getting taller. Nice work Al.
#54 Posted : 04 April 2018 13:13:53
Thanks guysBigGrin looking forward to the next pack where the made up limbs are functioned.
#55 Posted : 04 May 2018 16:23:03
Pack 12
This pack is mainly made up of testing movement of the limbs that have been constructed. First its the right arm and mine functioned as it should, a good start. This was followed by the left arm which although functioned as it should for the most part, had a smaller range of travel on one of its axis than the right arm so needs looking at. I also need to sort his right leg as I had no movement from it at all. Attention then returned to the build of Robi's left foot and ankle which was assembled and also tested fine.
#56 Posted : 04 May 2018 16:32:20
Good to see the little fella progressing Cool
#57 Posted : 04 May 2018 16:55:34
BigGrin Hi Al
Looking good. The lack of movement on the arm is usually the servo and it either needs resetting or a replacement.
Any lack of movement on a test is down to the servo closest to the non moving part so no movement at all means the top servo or connection is at fault. Mostly its the connection.
One tip is to leave as much slack as possible in the servo wire runs between the servos.
#58 Posted : 04 May 2018 17:06:10
Thanks Andy, thought the leg not moving must be a connection issue and will try resetting the servo in the arm BigGrin
#59 Posted : 08 June 2018 22:34:20
BigGrin Hi Al
Thanks Andy you were spot on with your diagnosis BigGrin after swapping the arm servo it works fine and the leg functions fine once I pressed the loose connection home.
#60 Posted : 08 June 2018 22:53:14
Pack 13
In this pack Robi's lower left leg and knee is progressed once another servo is tested and allocated its id. This was then functioned with no problems. The thigh servo was then tested and assigned an id before being fitted in position and a satisfactory function test carried out. The hip frame was then fitted and assembly then continued on the right leg with the fitting of the outer hip frame and rear hip frame, followed by another successful function test.
Guest (6)
5 Pages <12345>
This page was generated in 0.785 seconds.
