5 Pages «<2345>
Graeme's Akagi build Options
#61 Posted : 25 October 2017 13:53:33
Coming along a treat now Graeme BigGrin nice work.
#62 Posted : 25 October 2017 18:01:39
Taking shape very nicely.
Cool Cool Cool Cool
#63 Posted : 25 October 2017 23:37:43
Another very nice update Graeme, looking good.....Cool Cool
#64 Posted : 14 November 2017 15:38:30
Thanks for the comments. Another short update. A start was made on the bow elevator by assembling the floor and walls, Pic.1. After the structure had dried I noticed there was a slight bow along the length of the side pieces, Pic 2. After a little thought I rectified this by clamping a file along the length of the side and whilst clamped flat glued the outer strips to the side, Pics 3 & 4. This was then left clamped until the glue dried. Once the clamp was removed the side remained flat. The rest of the strips were then glued in place, Pic 5 and once dry the ends trimmed flush with the sides, Pic 6. The structure was then given a coat of matt varnish to seal the wood.
Whilst the varnish was drying I assembled the starboard bow hanger, Pics 7-9.
That’s it for now
pemberg attached the following image(s):
#65 Posted : 14 November 2017 17:36:40
BigGrin Going along nicely, the fun part starts soon when you fit the lift machineryCool
#66 Posted : 14 November 2017 22:29:12
coming along nicely, Cool
#67 Posted : 14 November 2017 22:36:45
Nice work Graeme, coming on very nicely.
DaDokta
#68 Posted : 15 November 2017 07:10:52
Nicely done!
Will the machinery be seen on the finished model?
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#69 Posted : 15 November 2017 09:42:22
Very nice update Graeme, making great progress....Cool Cool
#70 Posted : 15 November 2017 10:08:10
Thanks for looking in guys.
Walter - I will be installing all the machinery but haven't yet decided on how I am going to display the finished model. After reading Andy's (and other) builds I will be replacing the deck pieces with a single piece deck made from planked acrylic or mdf. I have thought of mounting the whole deck raised on clear acrylic rods to show the internals but I will make a final decision later in the build.
Sticky Wickett
#71 Posted : 15 November 2017 10:48:23
Great job so far Graeme!Cool Can't wait to see all of the detailing taking shape!
Phil W.
#72 Posted : 15 November 2017 12:32:25
Sounds like you have some interesting modifications lined up for this one.
Look forward to more of this as it looks a really nice model.
#73 Posted : 15 November 2017 12:36:38
Moving along nicely Graeme, look forward to seeing how your mods turn out BigGrin
#74 Posted : 15 November 2017 14:16:44
Oh yes i remember doing those with all the little wheels etc and the sting for the cablesBlink looks great GraemeDrool regards PhilCool
#75 Posted : 31 December 2017 10:18:39
It’s been a while since my last update but the build has continued between other projects. The central hanger was built, Pic 1 and Pic 2 shows it with the metal casting sat in place. Pic 3 shows the bow elevator, port and starboard bow hangers and the central hanger.
The main hanger is made up of several modules. Pics 4 & 5 show the first one made up (it is pictured upside down as it was more stable this way due to the location tabs at the bottom).
An additional piece was then added to the starboard bow hanger, Pic 6. The central elevator was built in the same way as the bow one, I’m afraid I forgot to take a pic at this stage.
The port side of the main hanger was built next, Pics 7 & 8 followed by the aft elevator, Pics 9 & 10. The stern hanger frame was built, Pic 11, then clad with planking, filled and sanded, Pic 12. Two reinforcing pieces were also added to the stern hanger wall, Pic 13.
Finally, for this update, seven ribs were added to one of the internal hanger walls. In order to keep the ribs level I clamped a ruler along the upper level of the ribs, Pic 14, then glued the ribs in place butting the tops up to the rule, Pics 15 & 16.
#76 Posted : 31 December 2017 13:48:45
Nice work Graeme BigGrin will you be displaying this with open flight deck so you can see the internals ? regards PhilCool
#77 Posted : 31 December 2017 14:37:43
Great to see you back on this one Graeme, very nice looking work on show....Drool Drool
#78 Posted : 31 December 2017 20:08:45
BigGrin Looking good Graeme and nice workCool
#79 Posted : 31 December 2017 21:06:20
Looking very nice.
Certainly a lot of parts going into the hanger assembles.
#80 Posted : 01 January 2018 09:53:46
moor good progress, suddenly all those parts will come together and you will see another jump forwardCool
5 Pages «<2345>
