5 Pages «<345
Graeme's Akagi build Options
#81 Posted : 01 January 2018 11:53:39
Some lovely work going on there Graeme.ThumpUp
DaDokta
#82 Posted : 02 January 2018 11:40:36
Great update!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#83 Posted : 05 January 2018 15:20:03
Thanks for looking in and your comments. Phil, I am planning on raising part of the flight deck, maybe on clear acrylic rods, to make the internals visible – well that’s the plan anyway.
I now, hopefully, have the hull ready for its final coat of primer but it will have to wait until the weather warms up a little as it’s too cold in the shed (even with a heater) for spraying just now. In the mean time I have been fitting the elevators out with their hardware.
Pic 1 just shows the bow elevator with its pulley placement template in place. I gave all three elevators a coat of grey paint (applied by brush) prior to fitting any parts. Pic 2 shows all three elevators after painting with their respective templates fitted and Pic 3 shows the bow elevator after the pulley positions had been marked and the template removed.
The motor shaft is supposed to fit over the drum shaft and into the gearbox but , as Yaturo and Andy pointed out in Andy’s build log, the drum shaft sits too high and fouls the motor shaft. To rectify this I built up the bases of the motor and gearbox assemblies with scrap plastic card so that the motor shaft just clears the drum shaft, Pics 3 & 5.
All the metal parts were then cleaned up, fixed to tape and sprayed first with metal primer and then with grey paint, Pic 6. The motor, gearbox and drum assemblies were then glued in place together with the floor pulleys and those at the top of the sides, Pic 7. I deviated from the instructions in that instead of fitting the cables to the drums before gluing the drums in place, I cut the cables longer than specified (using thread I already had) and first glued one end to the counter weights then threaded the cables through the top pulley, down the side wall, Pic 8, around the floor pulleys and then round the drum. The pulley at the bottom of the wall was glued over the cable prior to finally gluing the cable to the drum.
Pic 9 shows the first elevator completed and Pic 10 shows all three elevators together.
It is now a waiting game for the weather to get a little bit warmer to allow me to heat the shed sufficiently to be able to spray the hull.
pemberg attached the following image(s):
#84 Posted : 05 January 2018 16:32:19
Those elevators look excellent GraemeBigGrin top workDrool Drool regards PhilCool
#85 Posted : 05 January 2018 18:52:59
Great detail in the lifts. Looking good.
Cool Cool Cool Cool
#86 Posted : 05 January 2018 23:38:27
Beautiful work Graeme, credit to your skills and patience.....Drool Drool
#87 Posted : 05 January 2018 23:40:06
Very nicely done, pulling along nicely (joke intended). I will go away again now Blushing
#88 Posted : 06 January 2018 00:04:20
Great job Graeme BigGrin the lifts look good.
#89 Posted : 06 January 2018 01:13:43
BigGrin Nicely done on the internals, bet there was a sigh of relief when they were all doneCool
#90 Posted : 06 January 2018 11:13:51
Beautiful work Graeme, they look greatLove
#91 Posted : 06 January 2018 14:36:51
Thanks for the comments. You are right Andy, there was a sigh of relief. The next sigh will be after the portholes are done but that's a little way off yet.
DaDokta
#92 Posted : 08 January 2018 08:54:29
Looks like some fiddly work, Graeme! Well done, looking great!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
EmperorMing
#93 Posted : 21 February 2018 20:30:43
Nice build diary Graeme...love the work you are doing..might take this build on next when Yamato is all done....keep up the good work and keep the pics coming Cool
#94 Posted : 21 February 2018 20:58:26
Thanks for looking in, I'm just waiting for the weather to warm up so I can get the hull sprayed.
5 Pages «<345
This page was generated in 0.081 seconds.
