6 Pages <1234>»
IJN Mikasa 1902 by Jase Options
#21 Posted : 08 January 2018 15:40:24
ian smith wrote:
Great start jase. look forward to seeing your progress.
Ian Cool BigGrin
Thanks Ian its a very pretty shipDrool
#22 Posted : 08 January 2018 15:46:23
Very nice start Jase BigGrin looks great so farBigGrin regards PhilCool
#23 Posted : 08 January 2018 22:10:41
Hull Construction Part 3, Scuttles part a.
Adding etch scuttles makes a big difference to the look and feel of a ships hull, even if you have drilled out the scuttles. Comparing picture 1 and 2 you can immediately see depth of detail the etch brings.
The process of adding the scuttles is relatively simple if not a little repetitious. The scuttles are carefully removed from the fret using a sharpened No. 11 blade.
A small amount of medium CA glue is decanted into a stable container, I use a milk bottle top. I use a length of fine wire in a pin vice to apply the glue around the edge of the drilled out scuttle as in picture 3.
I use a wax etch placing pencil to pick up the part and, with a steady hand, place the shuttle in place, taking care to keep an eye on the parts orientation; as in pictures 4, 5 & 6
Some of the parts need to be trimmed to fit. any scuttle that looks like it may foul is dry fitted first and then trimmed as required, this can be done with the same No11 blade. See picture 7
So as not to lose the scuttles removed from the fret I tend to do a small number at a time, completing a section of the hull at a time.
Thanks for looking in
jase attached the following image(s):
#24 Posted : 08 January 2018 22:50:46
Nice work Jase, some good detailing of the hull.
Cool Cool Cool
#25 Posted : 09 January 2018 00:27:28
Looks good Jase, painstaking work and not easy to ensure they all line up correctly. Any misaligned and it tends to stick out like a sore thumb.... nice work.....Cool Cool
#26 Posted : 09 January 2018 12:24:13
Thanks both for looking in, I have to admit this is one of those kits you cannot put down Cool Cool
#27 Posted : 09 January 2018 15:16:15
Looking great so far.
#28 Posted : 09 January 2018 16:30:48
Great stuff jase BigGrin really liking thisDrool Drool regards PhilCool
#29 Posted : 09 January 2018 16:39:46
Looking great Jase, nice start with this one.
CaptnBirdseye
#30 Posted : 09 January 2018 18:04:06
Rank: Superelite
Hi jase
I really must compliment you on your build diaries. They show great detail both on the kit itself and your build techniques. Really impressed. Even more so that you didn't call your build 'Mikasa Su-Casa' LOL LOL LOL Sorry couldn't resist BigGrin. keep up the good work
Gray
#31 Posted : 09 January 2018 21:58:59
Carl, Phil and Graeme. many thanks for looking in and taking the time to comment, always good to know people are enjoying a build, many thanks chapsBigGrin
#32 Posted : 09 January 2018 22:01:20
CaptnBirdseye wrote:
Hi jase
Gray
LOL LOL LOL LOL LOL
Many thanks for such kind words, Its nice to share ab=nd I always appreciate feed back and other peoples thoughts on my build
many thanksThumpUp
#33 Posted : 09 January 2018 22:09:20
Great work Jase, they look excellent. Definitely picks out the depth, looks like it was a tedious job, but well worth while.
#34 Posted : 09 January 2018 22:23:20
Not as fiddle as the grab Handels though Blink Crying Mellow
#35 Posted : 13 January 2018 20:32:33
Hull Construction part 4. Gun shutters.
As The build progresses down the hulls sides there are more than just scurries to consider. there are grab Handels, davits and because this is a pre-Dreadnaught quite a few gun ports which all have shutters.
The Kit comes with plastic gun shutters but those supplied in the MK1 set have more detail and a better scale thickness.
The for and aft guns also have a grill. the kit supplies Photo Etch parts for this, however the MK1 set had a finer finish so I went with them. Photo 1
Having removed the etch parts, Photo 2, they were carefully folded using a small blob of medium CA to hold them together. no folding aid needed they fold easily. the parts were then put in the correct position along side the hull. A number of them are slightly different sizes so car is needed not to mix things up.
Because the guns do not retract the shutters close around the barrel. you can display the model with the shutters open al closed, I have opted for open.
medium CA was used to fix the shutters in place. I found slightly bending the hinges with tweezers first aided mounting the shutters. Photo 3, Photo 4,
its worth checking the shutter positions before fixing into place as some can fowl on grab Handels or, as in photo 5 & 6, the anchor chain guid.
Some shutters will fold out against the hull, others will not as in photo 7, but carefully placing the hinges in the recess designed for the plastic parts allows for easy mounting and adds some interest I think.
once in place the shutters give you an impression of a powerful ship bristling with guns.
#36 Posted : 13 January 2018 21:32:43
Nice update JaseBigGrin nice small and fiddley Drool Drool regards PhilCool
#37 Posted : 13 January 2018 23:34:27
BigGrin Looking goodCool
#38 Posted : 14 January 2018 00:03:33
Looks excellent Jase, they really make the guns stand out. The middle shutter on picture 8, looks like it should be the other way round. Love
#39 Posted : 14 January 2018 13:29:09
Your Not wrong Mark and not the only forum member to spot it! Thanks for flagging.
I have always said my diary are warts and all LOL LOL I did correct the shutters but for another reason that will be in a later post, my diary is a little behind my actual progress
Many thanks all for looking in.
#40 Posted : 15 January 2018 20:51:43
Hull Construction part 5. Davits.
As I progress along the hull there is the occasional folded davit that needs to be fitted before scuttles can be added.
the kit parts have two circular blobs to represent the hook and pulley but the etch update set has this covered. Photo 1 shows the kit part before modification to allow the addition of the etch and the 2 etch parts used. the two parts fold to make a thicker pulley wheel.
the two moulded on pulley wheels are just snipped off with a sharp blade.
the etch was folded with tweezers, I did not glue the undersides as the glue used to attache them to the davit are will be enough to hold it all together.
I found it easer to attache the davit to the hull before attaching the pulley wheels.
The finished effect is excellent
6 Pages <1234>»
This page was generated in 0.903 seconds.
