Nice progress - i`m watching with great interest!Greetings, Walter
Thanks Walter, appreciated..... Progressed to making up the 3 hatch covers, the process is the same for all.. Using a 2 x 5mm strip and cut the required amount of lengths for each hatch cover. Cleaned up the edges and glued together number of lengths to give the correct size for each hatch cover. Left to dry and sanded the surface of each to give a smooth finish. Used a 1 x 3mm strip and cut lengths to fit around the perimeter of each hatch, sanded smooth and glued into position, left to dry. Gave each hatch cover a coat of primer before applying coats of our lovely bright red.... Took 12 brass eyelets and attached a brass ring to each before applying a blackening solution. Once the effect was achieved, washed the eyelets to remove remaining blackening agent, then cut the stem of the eyelets down to a length of 2mm. Drilled a 1mm hole 2 mm from each corner of the hatches and glued an eyelet into each hole, left to dry. Glued the hatches into position on the deck, left to dry. This brought to an end stage 21. Until next time, happy modelling all..... Regards Alan Gandale attached the following image(s):
Hi Alan. Looking fantastic. Great work on the hatches. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
You were right about more bright red, certainly not a drab ship 😎 Which paint are you using for the red? Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Nice work on the hatches Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks guys, appreciated..... @Jase, not using anything special in terms of paint, red I'm using is Daler Rowney System 3 Acrylic, Vermillon Hue 588. Comes in a tube.... Regards Alan
Well stage 22 has to be the smallest stage done to date, here it is for what its worth..... Took 6 brass eyelets, attached a ring to each and coated them with blackening flued. After they were washed I then fitted them to the deck in the positions outlined in the instructions.....  .. This brought an end to stage 22 but in the next stage we start the process of fitting the next deck, so until then, happy modelling..... Regards Alan Gandale attached the following image(s):
This stage of the build has us fitting the next deck. This started by test fitting the two forward deck sections and happy to say that only very minor adjustments were necessary to get a good fit. Once happy, removed the sections and turned them upside down. Marked off and masked the areas outlined in the instructions, this where the deck is supported and the masking is to ensure the areas are clear of paint giving a good gluing surface. Out came our trusty red paint again and painted the underside of the deck, left to dry before gluing the deck in place. Then test fitted the two rear sections, again only minor adjustments were necessary for a good fit. Once happy, glued the rear section into position. This brought an end to stage 23, the next stage has us planking the deck just fitted so until then, happy modelling all.... Regards Alan Gandale attached the following image(s):
Hi Alan The ship is looking great mate, can you tell me why the underside of the decks are painted ? Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gibbo wrote:Hi Alan The ship is looking great mate, can you tell me why the underside of the decks are painted ? Hi Gibbo, Thanks for looking in, appreciated... I'm constructing this build as per the instructions and asked myself the very same question, it is what the instructions tell us to do so it was done. What I did notice afterwards though and its not very clear in the pics, is that there is a distinct red hue now to the lower deck area, a hue that wasn't there during the test fitting of the decks.... Cheers Alan
Stunning work again Alan, Very bright but very nice indeed.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks Chris, she is bright and colourful but the more I do the better she actually looks with all this colour.....  .. Nice change to be working on something like this..... Regards Alan
Nice work Alan, she’ll certainly brighten up your day. Mark Regards Markwarren (Mark) Admin
 Very nice work Alan , really loving this build Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Alan. great update, looking fantastic. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Mark, Martyn, Ian thanks for looking in and the kind comments, appreciated as always. In this session we move onto planking the second deck. This was done using 0.5 x 4mm veneer strips, giving the edges of each strip a very find sand to ensure they marry against each other nicely. Starting from the centre join line of the deck sections, laid planks to cover the centre section of the bow area moving onto to covering the centre section of the stern area. Made sure I marked any necessary cutouts for the masts etc. With the central deck area completed then moved on to complete the decking on the port and starboard sides, trimming and filling gaps where necessary up to the bulwarks. On the longer lengths the strips were staggered at frames 6 and 11. This ended stage 24 and by the looks of things stage 25 will be another short one. Until then, happy modelling all... Regards Alan Gandale attached the following image(s):
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
Hi Alan wonderful work as always with you , a pleasure to follow
 Nice work on the deck planking Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks guys, appreciated.... Regards Alan
I can see that red hue now, lovely job on the planking Alan. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Guest (29)
