More bits being chopped off, there was a rather thick beam running underneath the front of the Poop Deck so to give myself a bit more of a chance of getting things in there it had to come out, the photo etch i bought which was originally designed for the 1/100 Heller plastic kit is a little oversize for this 1/100 so a bit of jigging around is going to be needed and all the space i can get i will take, i also had a bit of plastic grating and decided to make the flag lockers with that and frame it with a coffee shop stir stick. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
The Flag Lockers were shaped and painted and i didn't have to do much to them to make them fit with the angle of the transom due to the overhang of wood at the back of the lockers, just a bit of filing of the plastic to make them flush, i also added two Kevels either side of and just forward of the ships bell on the forecastle. File Attachment(s): Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Hi Gibbo If your looking for buckets try here:- http://www.jotika-ltd.co...24768/Fitting_SfitA.htm
Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Paul. Flag lockers look really good. seems like your victory is having a major refit. look forward to seeing what you do with her. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Another nice update, changes you're making is going to make the world of difference.... Regards Alan
You are doing a fantastic job with your Victory-rebuild!Greetings, Walter
Thank you Walter, Ian and Alan for your comments, always very much appreciated, this time around i have been capping the Gunwales from the stern to the back of the forecastle with some coffee stirry sticks to give it a bit more width to take the photo-etch hammock cranes and adding the kevels on the quarter deck, i have also assembled the photo-etch skylight for the poop deck. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,275 Points: 22,132 Location: Northamptonshire, England
Some nice work going into this.Looks excellent. Mark Regards Markwarren (Mark) Admin
Nicely done Gibbo and I do like that skylight, looking good..... Regards Alan
That Skylight looks great!Greetings, Walter
Looking great Paul!  That skylight saves so much work! Are you going to glaze it with acetate or the Micro-'whotsit' (can't remember the name of it now!) Love the coffee stirrers, you wouldn't believe how many of those I've collected, half a dozen at a time. How did you bend yours over that curve? (Sneakily collecting tips here!) Keep them coming! Robin. First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:Looking great Paul!  That skylight saves so much work! Are you going to glaze it with acetate or the Micro-'whotsit' (can't remember the name of it now!) Love the coffee stirrers, you wouldn't believe how many of those I've collected, half a dozen at a time. How did you bend yours over that curve? (Sneakily collecting tips here!) Keep them coming! Robin. Hi Robin I am planning to use the Humbrol Micro "whotsit", DaDokta used it recently on his skylight and i like the effect, if i decide to cut the deck open under the skylight and put beams in underneath i will probably use the acetate so you can see it, the coffee stirrers i soaked in water and used the stem of a soldering iron to get the tight curve, i had to curve the length of them as well for the poop deck and for that i used pins to get the gentle curve and left them to dry, i found some curved ones yesterday in a cafe while out walking the dog, but hey ho too late now. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
That'll teach me! I always look for the completely straight ones when I'm 'acquiring' Now I'm back home I've got the bottle in front of me and it's Micro Kristal Klear that I used on my skylight. It gives a lovely antique glass effect compared to the ultra clear acetate and you can still just make out the beams inside. Great updates! Robin. First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:That'll teach me! I always look for the completely straight ones when I'm 'acquiring' Now I'm back home I've got the bottle in front of me and it's Micro Kristal Klear that I used on my skylight. It gives a lovely antique glass effect compared to the ultra clear acetate and you can still just make out the beams inside. Great updates! Robin. well that's that then, Micro Kristal Klear or Humbrol clear Fix it is then, thanks Robin. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Paul. skylight looks fantastic. are you going to glaze it using micro crystal clear. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Paul. skylight looks fantastic. are you going to glaze it using micro crystal clear. Ian. Yes Ian i am, i bought some Humbrol Clear Fix. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
I have been working on the Poop Deck Rail, firstly i took the PE rail and to cut it down to make it fit, the Victory has eight posts on the rail but mine only has six i didn't really need to use it but it has the bucket handles attached to it and the PE wasn't cheap so i'm going to use as much of it as i can, the Heller plastic kit obviously has a wider beam than this one, the rail was made up of coffee stirry sticks and 3mm X 3mm square, the PE beam was glued on top and the hammock frames were attached in to each post, the netting is for another time and the buckets ? well i'm gonna have to think about that one. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Very nice indeed Gibbo, love the detail...... Regards Alan
Today i received a large parcel, the Heller 1/100 scale of the Victory, i originally bought it to maybe barstoolise it for certain bits and pieces, it cost me £35 off ebay, not bad for a model that retails at around £130, i was mainly looking at it to see what the cannons were like and whether they could replace the DelPrado ones and also use the sweeping bow sections, but i think i'm going to use the bow section as a template and using the measurements recreate it out of wood so there will be more hacking bits off when the time comes, once i have what i need from it i will either build it OOTB or relist it, it's a lot of model for the money. Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Guest (14)
