birdaj2 wrote:Laszlo
Another very nice update.
Yourwork is very neat indeed. Thanks Tony, much appreciated. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Making minor adjustments is all part of the art of building these models and think you're doing great job in working your way through this one..... very nice work indeed..... Regards Alan
Great update! Your heads-ups and tips will come in handy once i start the masts!Greetings, Walter
Hello All, I'm confused now... I just tried the mizzen mast into it's position in the hull and the intended deck line, as directly measured from the plan (not the written dimension), it's now sitting 3mm below the actual poop deck surface.  This 3mm is exactly the difference between the written dimensions and the "direct-measurement" I know that everybody said, including the editorial comment from Tomick, that we should follow the direct measurement method instead of go for the written dimensions but now I'm not sure that it was the good choice. Specially for the mizzen mast where the mast collar is triple thick compared to the other masts. Now, again, my lower binding seems a bit too close to the poop deck surface. I had similar issue on the fore mast where the inaccuracy of the plan caused to ignore and not fit the lowest binding, otherwise it would be unrealistically close to the mast collar. With all my respect to the experts, I now wish I was follow the written dimensions... well... it doesn't matter now, but I still will build up the bottom of the mizzen mast to bring the intended line back to the actual deck surface. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Issue 78: - 3 mm extension added to the bottom of the mast to bring the deck line on the mast to level of the poop deck (see my previous post) - lower mizzen mast painted. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Didn`t you put your mast dowel into the hull and mark your very own deckline before doing all the shaping?
I think every model has small variations in deck-height so the instructors can`t exactly know how far the dowel goes into the hull.
But anyways you solved the Problem - so no damage done!Greetings, Walter
DaDokta wrote:Didn`t you put your mast dowel into the hull and mark your very own deckline before doing all the shaping?
But anyways you solved the Problem - so no damage done! Hello Walter, No I didn’t, for the other two masts the line from the plan exactly matched with the deck line on the model. Also the deck line vs. dowel resting point inside the hull is defined by the laser cut frames, assembled on the very early stages. The poop deck is resting on the frames as well as the dowel. Therefore, if the plan would be correct also assuming that the laser cut was precise, then there shouldn’t be 3mm difference... and if I would have followed the written dimensions then they would match. Anyhow, the deck line is sorted, however I believe that in overall my mizzen mast will be 10-15 mm shorter once fully assembled compared to the correct 1:84 scale. But maybe I’m wrong and everybody else is doing it right. If I would know the height of the mizzen mast above the poop deck on the real ship it could be easily checked. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
In the afternoon i can have a look into my books - maybe i can provide you with a correct measurement.Greetings, Walter
DaDokta wrote:In the afternoon i can have a look into my books - maybe i can provide you with a correct measurement. Hello Walter, It would be great if you could find out the height of the mizzen mast above poop deck level on the real ship. Then we could calculate how much would it be on 1:84 scale. Yesterday I made a quick calculation on the DeAgostini plan. The difference between the given dimensions and the graphics dimensions is 20mm after the mast is fully assembled (lower + top + topgallant). I now stopped my build and ordered some 8mm dowel from Cornwall Model Shop. I’m happy to re-start the lower mizzen mast if the calculation show that it’s currently too short. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Unfortunately i didn`t get home yesterday till late at night. Should be earlier today - then i will have a look!Greetings, Walter
Ok here are my measurements from McKay s book:
The overall height of the mizzen above the poop deck level is 48 cm,
the lower mizzen mast is 20cm from poop deck levelGreetings, Walter
DaDokta wrote:Ok here are my measurements from McKay s book:
the lower mizzen mast is 20cm from poop deck level It must be me but I don’t quite understand... Obviously the 48 cm isn’t the real ship mizzen mast total heigh unless you made a typo error and you meant 48 meters. If you meant 48 cm then in what scale? Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
1:84 of course - as is the whole model!Greetings, Walter
Hello Walter, Thanks to confirm. Here are my findings: From the written dimensions total mast height from poop deck level to the top (ignoring the bead on top): 77 + 100 + 52 + 119 + 23 + 89 + 57 = 517 mm Same sections from the “direct-measurement”: 75 + 97 + 50.5 + 115.5 + 22.5 + 86.5 + 55.5 = 502.5 mm Taking your book as an official info the “direct-measurement” value is the closer one to the mentioned 480 mm. So the editorial comment was correct, we should ignore the written dimensions and take direct measurement from the plan. My concern was not proven so now I’m happy to carry on building. Thanks for your help. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Concern settled regarding the length of the mizzen mast, back on track to build it. - mizzen top glued to mast - support rails fitted ti upper section - upper section and mast cap painted black gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Looking very nice, Laszlo!
If you look at my build you will see that there are many differences between the original plans of the real ship and the official instructions.
And most of the measurements don`t exactly match.
Greetings, Walter
Today work on the mizzen mast: - mast cap dressed with eyelets and rigging blocks - cross trees assembled - hand mast assembled and painted - rope guide made - mizzen topmast carved, tapered, octagonal section added, bottom part painted black, ready to assemble tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Progressing nicely, well done.... Regards Alan
Quite productive day today working on mizzen mast: - mast cap, top mast, hand mast and rope guide assembled to the mast top - cross trees fitted to top mast - topgallant mast carved, tapered - octagonal section added - topgallant mast and mast cap fitted to the mase assembly and all painted black. With this the mizzen mast now fully assembled, only the dressing with rigging blocks left for tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Looking really good Laszlo. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Guest (33)
