Shaping (fairing) the hull Options
Ian Mc
#1 Posted : 27 May 2011 19:47:56
Hi everyone I've not posted for a long time as I'm so far behind that there always seems to be a an answer to any difficulties I have on here already.
But, I believe there is always room for one more daft question so here goes...
I've just started to sand the hull ready for planking - See told you I was behind - What is the best piece of kit to use to do this? At the moment I'm using one of those spongey sanding blocks with various grades of paper. This has been ok on the ribs but the stern is really driving me nuts. I have chronic tendinitis in elbows and wrists (no jokes please) and I'm getting quite miserable and running out of ibuprofen.
I don't seem to be getting anywhere is it really just a case of spending hours and hours sanding or is there another way.
#2 Posted : 27 May 2011 20:52:16
hi ian,I recommend perma grit sanding block,and a perma-grit small file set.they are the best,the block has 2 sides rough and smooth.
www.permagrit.com
expensive but very good. the files will do the hard work and the block will finish it,good luck.
Ian Mc
#3 Posted : 27 May 2011 21:14:05
Thanks Karl. Just had a quick look on the link you gave me and they seem Ideal. I just need something that's going to wear it down a bit quicker than sandpaper. I've been sanding away and I just know that tomorrow my elbows and fingers are going to be seized.
These file thingys look like they'll be more precise as well.
I had trawled the internet looking for something like them but it' s reassuring to get a recommendation.
Cheers
OuchHuh Just checked out the prices, but if it's going to save my little pinkies then it's got to be worth it.
Dontshootme
#4 Posted : 27 May 2011 23:48:36
I'll second Karl's recommendation...pricey but well worth the money.
Mike Turpin
#5 Posted : 28 May 2011 00:09:53
Tomick originally recommended Perma-grit to a number of us so that just have to be the things to use!
Mike T
Ian Mc
#6 Posted : 28 May 2011 00:37:39
Thanks to you all. I'll be ordering some permagrit stuff asap. I suppose if I'd kept up with the build I'd have known. In the meantime I'll practice bending planks with my knew electric plank bender (that wasn't cheap either)
jimbobuk05
#7 Posted : 28 May 2011 12:44:54
Hi Ian,
What I have been using is a set
of mini files from Wilkos. They
are very good. Come in a variety
of shapes; square, round, triangle,
circle, flat, and curved. They
have been fantastic. Great for jobs
like filing the gunports. And they
are very handy for shaping the hull.
They obviously wont be as good as the
perma-grit ones. But then again they
only cost a pound or two. So, before
you shell out on something expensive,
give them a go. They might work for you.
Good luck
Jim
This page was generated in 0.329 seconds.
