38 Pages «<7891011>»
Garth's Black Pearl Options
Garth
#161 Posted : 22 January 2018 08:34:51
Hi All,
Back to some actual modeling again. I'm glad to be done with the fiddly bits.
I found it easier planking the second deck off the job. I kept it in two halves, running down the centre line if the ship. I measured the coffee stirrer and halved the dimension and drew a line along the deck. My intension is that the coffee stirrer will overlap the other half of the deck part hiding the seam.
Before a started the planking, I taped the decks together and made sure that they fitted comfortably.
I laid the centre plank first taking care of its position. Once it dried I laid the remaining planks. I planked over the smaller openings and will cut them out once dry.
A couple more test fits as I approached the slots for the bulkheads and eventually everything fitted snugly.
Once the coffee stirrers were dry, I flipped the deck and scribed some lines on the underside. This will resemble the underside of the deck. I’m not sure how much will be visible though.
kind regards,
garth
Garth attached the following image(s):
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#162 Posted : 22 January 2018 10:00:10
Very neat and tidy work as usual Garth, all looking good.... Cool Cool
Gibbo
#163 Posted : 22 January 2018 14:43:03
There's some great little bits going into this, love the lighting, love the skeletons.
Paul
Garth
#164 Posted : 02 February 2018 06:23:01
Hi Alan & Paul,
Thanks for looking in and for the inspiration.
Kind regards,
Garth
Garth
#165 Posted : 12 February 2018 10:02:37
Hi All,
I Stained deck using Light Oak wood stain. I like the alcohol-based stains as they dry pretty fast.
Once all was dry, I fitted the deck to the ribs. Fortunately, the deck has been in and out a couple of times and is a fairly loos fit. This is important, should the components be forced, they may move some parts out of alignment and end up with a warped model.Cursing
Kind regards,
Garth
#166 Posted : 13 February 2018 13:17:49
Hi Garth.
decking looks really good. love the colour.
Ian Cool BigGrin
Garth
#167 Posted : 15 February 2018 14:25:55
Hi Ian,
Thanks for looking in and for the kind words.
Garth
Garth
#168 Posted : 16 February 2018 08:59:16
Hi All,
Started Starboard side panels. I fitted the external panels as per the instructions, but the internal panels are devoid of any detail.
Following an old Pearl blog, (Thank you Swordfish Fairey) I liked the offset between the black and Light oak colour of the internal wall sections.
To achieve this, I scored lines to represent planking, darkened them using a B4 pencil & stained using Light Oak wood stain. Coffee stirrers to the rescue again. I painted them and some left-over Victory planking black to resemble the internal structure and glued them to the scored piece.
Kind regards,
Garth
CaptnBirdseye
#169 Posted : 16 February 2018 12:11:52
Rank: Superelite
Hi Garth,
Read your post today. When you mentioned 'coffee stirer' i was so intrigued that i read your whole build diary! What a great idea, and loving your build, and colour of your deck.
Keep up the good work.
Gray
#170 Posted : 16 February 2018 14:36:50
Looks great Garth, doing a great job.
Chris Cool
#171 Posted : 16 February 2018 15:45:17
Really coming along great Garth BigGrin regards PhilCool
#172 Posted : 16 February 2018 23:45:00
Nicely done Garth and some nice tips too.....Cool Cool
travoski
#173 Posted : 17 February 2018 08:20:07
Hi Garth
Great build so far wow if only I had a little of your skills waiting for the next update
Trevor
If my ship's going down,I'm bloody well getting off
#174 Posted : 17 February 2018 08:51:49
Just caught up with your build, looking great. Love the decking colour.ThumpUp
Garth
#175 Posted : 19 February 2018 10:35:30
Hi Guys,
Thanks for looking in and once again for the kind words.
Garth
Garth
#176 Posted : 23 February 2018 13:48:44
Hi All,
Fitted the Port side panels. Applied the same treatment as with the Starboard side panels.
I have a commercial nailer, but it never seems to hold the pin properly. To rectify this, I made this nailer after I completed my Victory planking. The pliers just seem to give so much more control.
I have posted these pics in my HMS Victory build blog, but I will post them again here.
I cut a slot into both jaws of an old pair of long nose pliers to accommodate the pin head and filed a grove down the middle. No more twisting/rotating pins!!! BigGrin
Since posting that, I have learned that model railroad suppliers sell the exact pliers - with slots milled in for pinning model railroad tracks.
Kind regards,
Garth
#177 Posted : 24 February 2018 00:22:36
Lovely work Garth, do like your build methods..... Look forward to seeing more of your work.....Cool Cool
travoski
#178 Posted : 24 February 2018 04:44:58
Garth wrote:
Hi All,
Kind regards,
Garth
Nothing wrong with a few ice cold Windhoek Draughts while you build either
Trevor
#179 Posted : 24 February 2018 12:05:25
Great work Garth, loving the attension to detail.
Gibbo
#180 Posted : 24 February 2018 12:34:23
Very nice Garth, looking forward to seeing more
Paul
Guest (10)
This page was generated in 0.309 seconds.
