35 Pages «<1112131415>»
Laszlo For's Diary Options
gingerale75
#241 Posted : 24 January 2018 00:24:07
Today's work:
- mizzen mast fully dressed with rigging blocks
- started to carve the cross jack yard centre section for the octagon
Also painted the belaying pins for the mizzen mast but faced with problem and I might seek your advice.
I used metal primer and black metal paint (both from the admiralty paint set provided for the kit) on them however it's easily peeling off when I insert the pins into the holes on the collar.
I could work around the problem with inserting them first and then paint, but I was advised 10-15 posts ago not to glue them in place yet because I might need to remove them later on during rigging.
The other solution would be to make the 1.3mm holes bigger not to scrape the paint off when they're inserted but then the pins would be loose.
Have you got any other suggestions, e.g. paint type?
gingerale75 attached the following image(s):
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
#242 Posted : 24 January 2018 05:58:40
BigGrin Hi mate lovely job on the masts Cool I use a etch primer from Halfords for my metal parts but you have to make sure they are clean and dry before use Cool
Hope this helps
Martyn
gingerale75
#243 Posted : 28 January 2018 23:42:52
In the last couple of days I carried on working on the remaining yards:
- octagonal section fitted to the cross jack yard
- ends tapered with my well working pillar drill method
- slings, bindings and footrope supports added
- yard painted black and dressed with rigging blocks
- central octagonal section marked on the mizzen top and topgallant yards
As the mizzen mast was completed I test fitted all the masts to the hull...
Looks awesome, as a first time builder I'm very happy with the result so far. Cool
Happy building!
Laszlo
#244 Posted : 29 January 2018 00:21:28
Very happy you should be.
Cool Cool Cool
Looks great WTG.
gingerale75
#245 Posted : 05 February 2018 01:01:43
Ahoy Shipmates,
After couple of days break carried on working on the last two mast yards:
- octagonal sections added to mizzen top and topgallant yards
- ends tapered with pillar drill method
- slings, bindings and custom made footrope supports added
- yards painted black
- both fully dressed with rigging blocks
Happy building!
Laszlo
#246 Posted : 05 February 2018 15:34:04
All coming together very nicely, well done....Cool Cool
travoski
#247 Posted : 07 February 2018 09:57:16
gingerale75 wrote:
18/05/2017
started planking the lower hull. Veeeeeryyyy slow 😴 Bend one strip each side, then leave it dry its place. Then taper towards the bow and fix it. A pair of plank = 30+ mins... 😴😴
21/05/2017
two more layers of planking fitted on the sides and at the bow. Next one is bent and now drying ready to tapering, then glueing on its place.
Hi
I am a bit behind you at this point your model looks great what did you use for the filler in your pics is it balsa wood and if I may is there nothing that needs to be cut out where you placed the fillers your build is on my watch list to follow keep up the good work
Trevor
If my ship's going down,I'm bloody well getting off
gingerale75
#248 Posted : 07 February 2018 10:50:14
travoski wrote:
gingerale75 wrote:
18/05/2017
21/05/2017
Hi
Trevor
Hi Trevor,
Yes, I used balsa wood blocks to fill the big gaps at the bow and stern.
I didn't actually glued/pinned the hull planking into the balsa wood (only into the frames) but these fillers helped me during the sanding/shaping the hull prior planking to get it into the correct shape.
The balsa blocks fit in between the frame gaps, you don't need to cut anything out from the frames. You just cut a rectangular piece to fit between two frames, glue it there and then sand off the excess corner and shape in together with the frames.
I hope it helps.
Happy building!
Laszlo
gingerale75
#249 Posted : 11 February 2018 00:38:39
Today's work on Issue 81:
- driver boom and gaff tapered
- jaws and braket fitted
- both painted black
- fully dressed with rigging blocks
Now I finished all the masts, yards (except the bow sprit) and I'll go back to the skipped issues/steps and start working on the hull from Issue 66, painting the hull... Crying Blink Scared
Happy building!
Laszlo
#250 Posted : 11 February 2018 13:07:33
Booms look good especially with all the blocks in place,
Great build enjoying it
gingerale75
#251 Posted : 11 February 2018 17:55:53
Today I haven’t actually worked on the ship but made an adjustable stand using some leftover timber from previous DIY projects.
The work for the upcoming weeks/months will be on the sides of the hull.
For easy access it’s better when the hull is tilted.
Fleece material ordered to cover the surfaces to protect the hull from being scratched.
Happy building!
Laszlo
Garth
#252 Posted : 15 February 2018 14:17:28
Hi Laszlo,
I have just been browsing your build. Compliments on your great modeling skills and attention to detail.
I'll be following your build with interest.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Gibbo
#253 Posted : 15 February 2018 14:34:40
A very nice idea and well executed, your ship looks great.
Paul
#254 Posted : 15 February 2018 14:55:25
Great job with your build and I like the idea of the stand, it should make working on the sides a lot easier.
DaDokta
#255 Posted : 16 February 2018 08:08:26
Great idea with the stand - but in your pictures it looks very dangerous to me!
In the tilted position too much weight on the front side would make the whole thing tip over and thus catapulting the model to the ground.
Sorry, this was my first thought - of course you have thought of that and i dont`t have to warn you!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
gingerale75
#256 Posted : 17 February 2018 17:37:47
Hello All,
Thanks for the good comments about my stand, much appreciated.
Regarding Walter's (DaDokta) comment, yes, it looks dangerous Drool but the "tip over point" is still far away, actually it still can be tilted bit more vertical and still safely tilted. Cool
I'll also keep it in the tilted position only when I'm actually working on it.
For storage it kept vertically (3rd picture).
The legs at the back and front are adjustable (rotate), to provide easy access to the part/area where I'll work on it.
Happy building!
Laszlo
gingerale75
#257 Posted : 19 February 2018 23:22:22
Today the fleece material arrived and fixed to the stand with PVA glue.
Now I can carry on working on the hull without risking it to get scratched.
Cool Cool Cool
Happy building!
Laszlo
gingerale75
#258 Posted : 25 February 2018 23:25:53
The scary task started... painting the hull, Issue 66.
First I marked the rough position waterline.
Then painted a black stripe. As advised by the magazine I made the "edges" of the stripe feathered to avoid the stripe being visible when it's painted with the next layers.
Then re-drawn the waterline on top of the black paint. After it dried, of course. Laugh
Marking the waterline wasn't that easy because the height of it has 2 mm difference between left and right hand side due to slightly different position of the whales.
So I had to cheat on both sides to "bend" the waterline up/down towards the stern/bow to make sure they meet at the front/rear.
Then I used 2 mm wide masking tape all around the hull.
It was very tricky where the waterline crosses the bottom of the lower whale, there is a step.
It took a while but hopefully the step will look OK when painted, however I might need to correct it with fine brush, the masking tape doesn't wanted to stick on the edge of the whale.
Then I used a 6mm tape half way covering the previous tape to increase the masked area.
I nicely managed to bring the waterlines together at the bow/stern.
Tomorrow I'll paint the hull copper.
Happy building!
Laszlo
#259 Posted : 25 February 2018 23:46:29
Very nice work, a little tricky but well worth the effort you've put in.....Cool Cool
z8000783
#260 Posted : 26 February 2018 07:11:44
Groups: Unapproved
Looking nice Laszio, and really neat work.
Guest (15)
This page was generated in 0.637 seconds.
