Joined: 28/02/2017 Posts: 10 Points: 30 Location: Cypress, Ca
Hey all, I am well on my way to finishing the leg on my R2-A1 build. Only issue Im having is the shoulder sensor. Well, it's white and I think it might stand out on a black R2.  So my question is, what type of sensor is it? Infrared? I need to figure out a way to get it black (or at least dark). The plastic housing I will airbrush, but the sensor itself has me worried a bit. Anyone have any ideas?
Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Hi, it is a distance sensor like you would find on cars for the parking sensor. So it will be perfectly alright to paint it. I have painted mine. Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Outstanding! Makes this much easier :) Thanks
Please be aware that changing a component yourself from its 'as supplied state' by painting it for example would make it 'a non standard part' and therefore not covered by the free replacement service provided by DeAgostini for faulty parts. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for the heads up :) Chris arpurchase wrote:Please be aware that changing a component yourself from its 'as supplied state' by painting it for example would make it 'a non standard part' and therefore not covered by the free replacement service provided by DeAgostini for faulty parts.
Joined: 29/09/2017 Posts: 13 Points: 42 Location: Hudson FL
Well that answers my question too.I'm not going to paint it but I was curious what it did. Building: R2D2
An update on the shoulder sensor after I have painted it, all tested and works fine. Darren
