 Hi does any one have any idea when the engine and bulkhead can be added onto issues 42 and 43 Auric Gold finger
No idea at moment, all I know is it won't be before issue 58 Al
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,865 Points: 17,747 Location: ipswich
The bulkhead part actually sits 'just' inside the bodywork.
As the body is die-cast, I'm guessing it 'could' be fitted now. However - you may well have to remove it again when the body arrives so that it can be fitted at the same time as it will need to tuck inside the body below the screen.
 Thank you Guys for your Advice Auric Gold Finger
Joined: 19/11/2017 Posts: 41 Points: 135 Location: Marlow
Hello All,
I have fitted bulkheads to both my cars as they will slide into the bodywork when it becomes available.
Also I have built several of the Monogram E-types and the bulkhead fits very much the same as on our models so Im basing my comments on that fact. Also the number of pats that have to be screwed to the bulkhead logic says now is the time fit it.
If Im wrong there will be a lot of unscrewing going on my workbench.
Tony
 Thanks to all of you for your Advise very much Appreciated Auric
sounds to me as you are a big james bond fan, am i correct?
Just a thought Montydog...
You say you have fitted both bulkheads to you cars. I'm guessing you mean to the floor section.
My question is, how?
There are no fixings between the bulkhead and floor parts. How have you fixed them together?
Roy.
Message was deleted by User.
The fitting of the floors is very temporary using clips. Its been done to give
some idea how it will look in the end, there is obviously proper fittings for the floor probably
added to the flloor pan which should come later. I don't know what you think about the supply of
parts but they seem very slow infact the official build seems to be stuck on 50.
Also Roy how did you make the E type lightweight roof and windows as I would love to build one
Just like yours.
Regards Tony
The Chinese New Year always slows things up in Partwork world., the official build will continue just as soon as we receive parts
Hello Tony. My roadster tail end and hard top were made using wooden masters then a rubber mould to make the tail in resin. The roof and window parts were vac formed over the wood part. The originals are currently being re-done in the hopes of making the rear as a plastic part too instead of resin. roymattblack attached the following image(s):
Hello Roy
Thanks for your response
Do you have any chance to sell me the parts so I could build a lightweigt
Like yours
Regards Tony
