Update on my build Options
thomasmoult
#1 Posted : 01 June 2011 16:26:27
Hi everyone,
I thought I'd post some photos of my build so far!
Here is my version of the cabin partition; based on some photos I took on a visit to Portsmouth last year. One has been oiled to show the difference. I also bought some o.4 clear acetate to use as the windows, which I might also use on the stern later.
I built a deck over the stern gallery to give at least something to look at if I'm using clear acetate, its very dark in there so I think the level of visibility will be just right.
Painting the end of the cabin at the poop black:
Fitting the poop deck:
The poop edging strip will be replaced by 4x4 walnut when I next go home to work on her; I used the supplied strip as a guide to fit the inside bulwarks in, but its not fixed in.
Thanks for looking at my build. I will post more photos after I have done some more progress.
Tom
#2 Posted : 01 June 2011 16:52:59
Coming along nicely Cool
saintsman123
#3 Posted : 01 June 2011 16:53:28
Looking nice and tidy Thomas, is there any way you could re-post the partition door picture in a larger size, it looks really good, but I would like to see the detail better
Come on you Jimmies
thomasmoult
#4 Posted : 01 June 2011 16:59:34
I think theres a problem at my end; the photos were resized to 160 wide, but they still appear really big on my screen (i have to scroll horizontally). Are they really small on your computer?
Cheers,
Tom
Tiswas
#5 Posted : 01 June 2011 17:22:36
Nice looking model Tom. I agree with Saintsman, the images are on the small size, about 50x35mm. Double the size would be better.
TIS
thomasmoult
#6 Posted : 01 June 2011 17:41:19
I resized them to 640x480 so hopefully (!!) that will be better. On my screen they are tiny but clearly something is wrong at my end!
Hope thats better,
Thanks a lot,
Tom
benny
#7 Posted : 01 June 2011 17:46:56
very nice tom well done
cheers benny
Son of Bulwark
#8 Posted : 01 June 2011 18:02:03
Hi Tom! Cool
Great work mate! like the detail, a little tip as you have now closed the decks in at the gallery area put some masking tape over the ladders in the upper deck grates or if you drop a small part down there it will take an age to get it out!.
Sietse
#9 Posted : 11 June 2011 10:07:57
Hi Thomas
I like your extra details, its looks perfect .
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
2010 Hms Victory kit from Deagostini
In the meantime.
2011 Building MFV 1963 fishing trawler from plan.
#10 Posted : 11 June 2011 10:34:04
Nice finishing touches Tom ThumpUp
thomasmoult
#11 Posted : 11 June 2011 10:53:11
Thanks for the comments everyone!
I'm back home again later today so I can check if the canon shot has successfully been installed or not. Unfortunately some were dropped down Blushing but when the model is static it wont matter. I varnished them in, is this the method others have used?
I'll post more photos sometime shortly!
Also, I was wondering; the inside bulwark bit near the poop edge (where the curve was made with the coin) - will this have an internal bulwark strip fitted, as I was thinking of adding them but wasnt sure if it would alter any later additions?
thanks again,
Tom
#12 Posted : 11 June 2011 11:04:09
If your meaning the curved space on the inside, then its unlikley as part of the instructions, as this part has been completed.
This page was generated in 0.889 seconds.
