Pack 1 missing instructions?? Options
Desertfox030
#1 Posted : 07 February 2018 20:09:05
Rank: Newbie
I just received pack 1 of the constitution build, all that was in it was the materials pack and a poster of the constitution, there was no building instructions. Should there be instruction booklet with the first pack or will I get it at a later date?
pack 1.jpg (3,991kb) downloaded 74 time(s).
#2 Posted : 07 February 2018 20:49:30
Hi desertfox
If you click on the link below it will take you too the Conny order page scroll down slightly and you will see 5 tabs that turn green as your cursor passes over them. Click on the tab that says 'The Build' it will then take you to a page with the downloadable PDF instructions. The instructions currently have up to 'pack 11' on there so just pack 12 to be posted.
https://www.model-space....e-uss-constitution.html
#3 Posted : 07 February 2018 20:52:32
BigGrin Hi m8 and welcome to MS the build instructions are a download if you go to the top of the home page and click on ships and then after the page comes up click on the Constitution and go to build it will come up with the download Cool
Hope this helps
Martyn
#4 Posted : 07 February 2018 21:12:38
Hi, BigGrin
Welcome to the forum. Enjoy your Constitution build.
Cool Cool Cool
( Derek )
#5 Posted : 07 February 2018 21:44:15
Hi, welcome to the forum. If you resize your photos to approx 600x400 they will be visible on the forum without having to download them. The following link gives more info
http://forum.model-space....aspx?g=posts&t=244
#6 Posted : 07 February 2018 23:27:07
Welcome to the forum, hope you enjoy your build and your time with us.... Good luck with the build....Cool Cool
#7 Posted : 07 February 2018 23:47:08
Welcome to the forum, look forward to seeing your build start.
Chris Cool
This page was generated in 0.267 seconds.
