11 Pages «<56789>»
Roy's E Type Options
#121 Posted : 08 February 2018 15:28:09
Slow progress at present here as I've been waiting for a can of paint.
I wasn't entirely happy with the colour match on the floor with the car body so I ordered a rattle-can of the genuine article.
If you want the same paint, the code is:
Jaguar/Daimler 4 PEA ICI 184
It was £16 for a can, but it matches incredibly well.
Onward when the paint is fully hardened.
SLowner
#122 Posted : 10 February 2018 20:39:31
Roy,
Did the same as you - ordered an aerosol can of 'Jaguar Racing Green' from Halfords. Colour match perfect after a grey primer coat, although I felt it was not properly hard until several days later for some reason.
After the rear suspension, wonder where it's going next?
#123 Posted : 10 February 2018 21:29:13
Great work as always RoyDrool Drool regards PhilCool
#124 Posted : 12 February 2018 18:04:37
A small update and alteration here.
Another look at my friends E Type showed the top of the radiator to be flat all over, and the same width from end to end.
Further Googling showed a lot of E Types to be the same so I've altered mine.
There should be two braces between the rad and the bottom of the header tank support frame so these will be made and added.
goldfinger
#125 Posted : 13 February 2018 15:20:56
BigGrin Great Paint job on the Floor Roy i ordered and picked up the Same Spray Paint from Halfords this Morning and i only hope my Floors as good as yours when its done Gold Finger
#126 Posted : 13 February 2018 15:33:42
Thanks chaps.
Just a point about the paint - mine wasn't from Halfords so I can't vouch for that particular colour match.
If it works ok, let us all know.
Anyway, more on the radiator.
There should be two angled metal braces between the top of the rad and below the header tank.
Now made and fitted.
Roy.
goldfinger
#127 Posted : 13 February 2018 17:52:24
Laugh H Roy did you Spray both sides of the Floor in British Racing Green or just the one which i Assume will be the underside Gold Finger
#128 Posted : 13 February 2018 17:56:00
I sprayed all the underside, and the front two 'legs' on the upper side as parts of those panels will show through the engine frame.
Roy.
#129 Posted : 13 February 2018 18:10:02
Great work as always Roy BigGrin really like what you are adding Drool regards PhilCool
SLowner
#130 Posted : 13 February 2018 21:06:53
Roy,
I can vouch that the can of Jaguar Racing Green I got from Halfords is a perfect match. Not available off the shelf but special order took about a week. Not Halfords branded but from a company called LKG Coatings.
Brushed a bit on to repair a scratch I made on the bulkhead - pretty much invisible, finish on floorpan probably better than the body panels so far but, like I said, watch the drying time!
#131 Posted : 17 February 2018 14:26:05
Moving ahead a little more slowly at present as I've got a few other things on the go at the same time.
The floor is just about sorted and the rear diff and cage are assembled.
The rear parts were all repainted and I chose to make the shocks silver instead of the grey plastic.
Lots of de-seaming on the assorted components.
I'm guessing another wheel will be with us pretty soon - maybe two.
Roy.
#132 Posted : 17 February 2018 15:21:27
Looking really good Roy, worth all that effort.
#133 Posted : 17 February 2018 16:40:52
superb work RoyDrool regards PhilCool
CaptnBirdseye
#134 Posted : 17 February 2018 16:59:20
Rank: Superelite
Hi Roy,
It’s the attention to detail that really impresses me with your build. Love And there’s nothing like having the real thing to compare to.
Keep up the good work. Cool
Regards Gray
goldfinger
#135 Posted : 18 February 2018 15:27:39
BigGrin Hi Roy did you Clear Coat the Floor because i bought the Rattle can from Halfords based on the Code you gave me and the Colour Matches Perfectly with the Bonnet and Doors but looks a little Dull where as yours looks more like a Gloss effect Gold Finger
#136 Posted : 18 February 2018 17:40:54
It's probably just that I always lay my final coat on as what they used to call a 'flood coat'.
I worked in a display company years ago that had a paint shop. I was always gobsmacked at how one old guy there could lay paint on incredibly heavily and flat, yet it never ran.
Enough paint to look glossy, wet and smooth, but just before it begins to pool or run.
It takes a little practice but isn't difficult at our scale.
I'd never dare try it on a 1:1 car!
No gloss top coat.
Roy.
#137 Posted : 19 February 2018 16:53:53
Exhaust parts all de-seamed and repainted silver.
Now fitted to the floor parts along with the rear cage unit.
Next???
RM1
#138 Posted : 20 February 2018 13:54:01
That's looking really good. Lovely work as always.
Malc.
#139 Posted : 20 February 2018 17:44:28
Thanks Malc.
A really HUGE update today...
I've added the 'Marston' plate to the top of the radiator.
TRGRichie
#140 Posted : 20 February 2018 21:12:30
Enjoying reading this build diary very much. Great work
Rich.
AUTO FRUMP STOMPER
11 Pages «<56789>»
This page was generated in 0.259 seconds.
