Captn's Sultan Arab Dhow-ager Options
CaptnBirdseye
#1 Posted : 15 February 2018 20:28:18
Rank: Superelite
Hi all,
I have decided to make an 'out of the box' build of the the 1/60 Sultan Arab Dhow. Ordered last Friday, and package arrived today BigGrin. Can't complain about delivery times there.Cool
So, for today, i just wanted to open the box and take a peak at the contents. To gauge the quality of the kit as it were. Well i am pleased to report that it really does look like a quality kit! Well packaged, so no loose parts flying around, and good quality woods used (it's DOUBLE PLANKED!!!).
The frames are made from plywood, as is the decks. However, the hull formers are made from Sapeli, and the stern deck 'embellishments' are walnut. The second planking is also dark sepeli hardwood. It also has cloth sails, with cotton rigging, pre-formed anchors and deck barrels.
The instruction booklet is in full colour easily followed stages,in multiple languages.
All in all a very impressive little (470mm long) boat, that i think will be a joy to build.
Purchase and build details can be found on the Modelspace website here:
https://www.model-space....e-sultan-arab-dhow.html
Gray
GilShapley
#2 Posted : 15 February 2018 22:22:13
I built this Model a while ago now and did enjoy it. The model is also available through this forum and the build instructions are available as a PDF download on the forum site should you need them.
The only issue I had was with the rigging instruction, still the standard instructions of read twice build once applies.
Hope you enjoy this build
Gil
Current Build:-
#3 Posted : 15 February 2018 23:09:25
She's a great kit Gray and I'm sure you'll love the experience of building her. I know I'll enjoy following your progress as she slowly comes together..... Good luck with the build....Cool Cool
daffy09
#4 Posted : 15 February 2018 23:36:03
Hi Captn.
I'm sure you'll enjoy building this lovely little kit, and it will bring back happy memories to follow you with this build.
Happy building
David
PS: Hope you don't mind I've included a link to my own build diary in case you'd like to browse through it for help.
http://forum.model-space.co.uk/....aspx?g=posts&t=9049
#5 Posted : 15 February 2018 23:49:04
Nice kit Gray, I look forward to seeing how she comes along.ThumpUp
#6 Posted : 16 February 2018 01:49:16
Look forward to seeing your build progress. Great choice of kit.
Chris Cool Cool
#7 Posted : 16 February 2018 07:03:58
Ool, i loved building this kit a d she looks so good when built
CaptnBirdseye
#8 Posted : 07 March 2018 19:52:30
Rank: Superelite
thanks for looking in and your comments.
While waiting for some etch to dry, i thought i would make a start on my Sultan dhow build.
After carefully removing the the ribs and checking their fit, i loosely inserted them in order on the false keel without gluing.
Next the 2 bow strengtheners were glued in place, followed by the stern, making sure the tops of the strengtheners are in line with the top of the keel.
CaptnBirdseye
#9 Posted : 07 March 2018 21:44:59
Rank: Superelite
Next i fitted the main deck. Because the ribs were not glued, this made that particular task very easy. Using a pin pusher, i tacked the deck to the false keel along a line from bow to stern. The aft deck was fitted in the same manner. The stern bulkhead was a tight fit between the deck and rib ten, so once in place i watered down the glue and used capillary action to get the adhesive between the mating parts. The bow deck is fitted using the same gluing method, leaving a 10mm gap between the decks.Part 21, where the masts will sit is added next.
That's it for today's update. I hope you enjoyed it..
kpnuts
#10 Posted : 07 March 2018 22:05:14
It's looking good, it's bigger than I thought from the shot with your hand in it
#11 Posted : 07 March 2018 22:24:21
Great start Gray, nice to see how big it will be.BigGrin
#12 Posted : 07 March 2018 22:35:14
looking good
#13 Posted : 07 March 2018 22:42:18
Doing a really nice job. Great start to her. Look forward to more updates Gray.
ChrisCool
#14 Posted : 08 March 2018 00:29:27
You're off to a very nice start I see, all looks good....Cool Cool
Gibbo
#15 Posted : 08 March 2018 00:35:30
I did enjoy it thank you Graham, looking forward to seeing more.
Paul
DaDokta
#16 Posted : 08 March 2018 09:00:12
I have this one in my stash - so i`ll follow with great interest!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#17 Posted : 08 March 2018 23:17:24
BigGrin Nice start on her you will soon be plankingCool
#18 Posted : 09 March 2018 11:05:03
Great start, looking good.
This page was generated in 0.937 seconds.
