Joined: 27/03/2011 Posts: 72 Points: 186 Location: United Kingdon
Nice one, thanks for these, gives a great idea of how this thing comes together.
 Rank: Pro  Groups: Registered
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
Thanks for that. Disapointed the damper springs are plastic, so guess non working suspension !
Great photos Ian, We may be able to do some mods thats why I am waiting for more Parts. Skiddy if the springs are plastic we may be able to add metel ones, lets wait and see. MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Hi all, Quote:Thanks for that. Disapointed the damper springs are plastic, so guess non working suspension ! I can understand a slight feeling of disappointment at the shock absorbers seemingly being cast in plastic, but it may be too soon to make assumptions about their frailty or not being up to the job methinks?? I agree that it would have been nice to have cast metal parts for the shocks but please remember that ALL plastic parts on this model are made of ABS plastic, which is VERY tough and durable, so it should be up to the job of supporting the weight of this seemingly quite weighty model whilst still functioning properly, after all it will only be tested occasionally, as I don't think it is meant to be 'played' with on a regular basis as it is essentially, a 'Display' model, is it not?? The ABS plastic used is NOT like the harder and hence, more brittle, polystyrene plastic used in plastic construction kits made by companies such as Airfix, Revell, Tamiya, etc.?? Just thought I would make that point and as you say there is nothing to stop anyone fitting metal modded parts to the dampers (such as rams, etc) though I think DeAg would not use the ABS material for the parts in question if it clearly wasn't up to the task?? __________________________________________________________________________________________________________________ Regards, ... Kev.
Joined: 09/05/2011 Posts: 78 Points: 236 Location: N.Ireland
Might be a metal spring.Colouring looks more chrome than the other bits.
davyp1 wrote:Might be a metal spring.Colouring looks more chrome than the other bits. That's what i was thinking, it could just be put on the sprue
OK, just to be clear, the above photos are not an official release from De Agostini UK. The photos appear to be from the Japanese launch of this product.
In the UK we may well be changing running order or improving components from feedback we recieve from our Japanese colleagues who launched the product a few months before us.
So yes, we continue to supplty the high-quality Kyosho components but please don't take the above pictures as gospel!
Admin.
Thanks Admin. MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 27/05/2011 Posts: 8 Points: 24 Location: Merseyside
To me it looks like the coilover will actually consist of a steel spring as the damper appears to be in two parts which would imply that the suspension will have travel.
