Anyone have an issue with the foot side that dosnt seem to fit with the cut oit This is the cut out in place it all seems out of spec Hope anyone can help
Hi Check out the official R2 build diary, but you have probable got part LFR-05 located on the wrong side of the leg strut. This will put the foot casing in the wrong position and not fit in the slot. Hope that helps Mark Regards Markwarren (Mark) Admin
