 Rank: Semi-Pro Level 1   Groups: Registered
Joined: 26/01/2018 Posts: 68 Points: 210 Location: South Africa
[quote=Gibbo]Yeah that 1mm just leaves you a little room for manouvre, as for the pine fillers that's one tough material to sand, can you not order some Balsa online ? http://www.cornwallmodel...atalog/balsa-block.html[/quote] Hi Unfortunately online shops here are far and few between most won't ship one item only or will charge a lot for shipping as for ordering from overseas shipping is sometimes the same as the item you buy or even more the price of the Victory paint set from modelspace is 24Pounds and the shipping is 30pounds cornwall model boats is a great shop I have looked at their site Regards Trevor If my ship's going down,I'm bloody well getting off
Hi Trevor, Just been going through your build. Its coming along nicely - great job on the planking. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi Trevor, Loving your build. Have the Lego workmen gone on strike, as we haven't seen them lately Keep up the good work Regards Gray
CaptnBirdseye wrote:Hi Trevor, Loving your build. Have the Lego workmen gone on strike, as we haven't seen them lately Keep up the good work Regards Gray A few more of the lazy good for nothing swabs travoski attached the following image(s): If my ship's going down,I'm bloody well getting off
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,282 Points: 22,153 Location: Northamptonshire, England
Coming on very nicely Trevor. Mark Regards Markwarren (Mark) Admin
Hi All A little progress busy planking above middle gun deck then more gun port cutting II also have a cannon production line going on the side,oh I also assembled the supplied stand but she will go back on the home made "shipyard" for a little while.A question if I may is there any reason I cannot start the gun port linings in between waiting for glue to dry on the planks. Regards Trevor travoski attached the following image(s): If my ship's going down,I'm bloody well getting off
Looking good Trevor, well done....  .. Can't see any reason why you can't do the gun port linings as you go along.... Regards Alan
Nice progress and looks good. Congrats on your "Blue" medal for running a diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All Thanks for the comments guys Regards Trevor If my ship's going down,I'm bloody well getting off
Hi All again just seen I have been promoted the missus will have to call me sir soon Regards Trevor If my ship's going down,I'm bloody well getting off
Issue 29 Hi All Finished planking as per issue 28,marking out upper gunports I have discovered I have made a mistake on the lower gunports one of the forward gunports is supposed to be in the centre of the two rails as per the attached photo I marked,so the way I see it I have three options 1) leave it as is and mark the top one the same(not sure if this will interfere with other stuff later on)2) cut it bigger to the right as per the photo and try to fill in on the left hand side,3) try to fill it in and then re-cut it again.I would appreciate any help and advice on how to proceed Regards Trevor travoski attached the following image(s): If my ship's going down,I'm bloody well getting off
Hi Trevor
It will certainly look odd as the ports lie between the ones above and below. Have you decided what type of finish you are going for yet, paint or bare wood with stain perhaps?
If painting, it should be fairly straightforward to go with option 3, widen the port out to its correct position and use some spare planking to cover the gap. Then fill any gaps in the planks, rub down and paint. It should look fine after that. Filling in first and then cutting may be tricky since the planks will not be substantially fitted as the originals were.
Hi John Thanks for your advise,I think I am going to paint my model,so I guess anything I do will be hidden by the paint I was thinking option two cut bigger and fill in to the left as you suggested as well Regards Trevor If my ship's going down,I'm bloody well getting off
Hi Trevor, If it were me I would look to carefully remove the two short planks running between the ports to the left of the problem port. Widen the problem port on the right side then cut and fit the two new planks between the ports, this way it would only leave you with a small gap to fit just above the two new planks you've just fitted. Repair done and unlikely to be noticed....  .. Hope this helps. Also, can you ensure the pics you upload are set to 650 x 480 pixels in size, the would allow members to see the pics and read your text without the need to scroll across the screen. Regards Alan
Gandale wrote:Hi Trevor, If it were me I would look to carefully remove the two short planks running between the ports to the left of the problem port. Widen the problem port on the right side then cut and fit the two new planks between the ports, this way it would only leave you with a small gap to fit just above the two new planks you've just fitted. Repair done and unlikely to be noticed....  .. Hope this helps. Also, can you ensure the pics you upload are set to 650 x 480 pixels in size, the would allow members to see the pics and read your text without the need to scroll across the screen. Regards Alan Ok sorry about the pics I don't know what happened I normally set the pics to 144kb which I read is the max size of pic the last couple I did the text on top in photoshop it must have saved in a different size Regards Trevor If my ship's going down,I'm bloody well getting off
Hi All I have had a look at my pics they are 640x480 half the time I cannot see the pics on my diary and sometimes they open as large pics and sometimes as small so I am not sure what is going on weather it is me or the site Regards Trevor If my ship's going down,I'm bloody well getting off
travoski wrote:Hi All I have had a look at my pics they are 640x480 half the time I cannot see the pics on my diary and sometimes they open as large pics and sometimes as small so I am not sure what is going on weather it is me or the site Regards Trevor Looks like your treasure pic in post #51 is larger and is the one causing the problem. Rest of your pics now look ok.... Cheers Alan
Gandale wrote:travoski wrote:Hi All I have had a look at my pics they are 640x480 half the time I cannot see the pics on my diary and sometimes they open as large pics and sometimes as small so I am not sure what is going on weather it is me or the site Regards Trevor Looks like your treasure pic in post #51 is larger and is the one causing the problem. Rest of your pics now look ok.... Cheers Alan Thanks Alan I have deleted the post now things seem to be back to normal Regards Trevor If my ship's going down,I'm bloody well getting off
Hi All A little progress has been made,I have repaired the miscut bottom gun port and cut the top row on the starboard side now to do the port side Regards Trevor travoski attached the following image(s): If my ship's going down,I'm bloody well getting off
Looks fine, Trevor. I'm sure once it's rubed down, only you will know it's there.
Guest (8)
